XTVA XTS3000
katt02
Katt
Hi all,
I am thinking about buying an XTVA for my car. I have a uhf R2 xts3000 right now and I am thinking about getting an xts5000 vhf soon.
Would it be possible to set up the XTVA to amplify the power from the radio in the converacom, and then use a single antenna that can work with both bands? I would want to use the same XTVA for both radios with only one 440/2m antenna.
Thanks, Katt
n3obl
Ø
PA
If you want the XTVA to be multiband then you need to eliminate the amplifier as they are very band specific. No one makes one that is broadband over a wide range of freqs (VHF and UHF)
brndnstffrd
CT
Or you could run 1 amp for each band and use a selector switch before the amp with a combiner after, or swap cables to the necessary amp for each band.
There are chinese dual-band amps, but its not worth it to bother with them.
katt02
Katt
ok. Whatever I put in my car will have to be reliable because it will be used for ham stuff and official business
ME801
NV
Sti Co makes a dual band antenna. (and an all band antenna that doesn't need the duplexer)
