Yaesu: Yaesu 8800?
rescue69
Have a 8800 working good then today went to power it on and no display unless I disconnect it has continuous beeping sound no display. Any ideas how to correct this as soon as I plug it back on immediately will start beeping noise again?
Thanks!
AK9R
Super Moderator
Central Indiana
Are you sure that your power supply is putting out the correct voltage and current? Voltage should be measured at the radio.
Is the radio trying to transmit when it powers up?
rescue69
it was working then powered it off now continues beeping as soon as I plug it back in. Will try to power it off my USB to wall adapter that I use for programming.
radiotweester
Oregon
It sounds like you may have found your problem, but check the cable between the head and body. It doesn't matter if it's set up as remote or assembled as one unit. RJ connectors and IDC (crimped) stranded wires can be a great weak point.
