Yaesu: Yaesu FT400 Air Band Receive
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
FTM400 does a GREAT job with Airband RX.. Use mine to get ATIS before arriving at the airport..
VNR5338
But HOW do you put the radio on the air band. When scrolling through the bands, it does not have the 108-118 range.
mrweather
Did you set the proper receive coverage?
If not, go to Disp/Setup->Config->RX Coverage and set to "wide". Access the airband by going into VFO mode and manually keying in frequencies or using the dial.
