Hello all,
I purchased a yaesu ftm-400. I hear this strange noise coming from the radio unit when I transmit. It sounds like a series of relays chattering. the clicking doesn't have any kind of defined pattern. It only happens on transmit, and the condition doesn't happen every time I transmit. When I do hear it, it can be just a few in succession, or sometimes a second or so of this grinding going on. Currently testing this on a bench on UHF, power output currently set to low and I'm measuring around 3.7w output, SWR around 1.6. Antenna is a mobile mag mount sitting a few feet behind me on a metal filing cabinet. PSU is a linear rated at 10w but should be sufficient for low power transmit testing.
Any thoughts on what this noise is and what could be causing it?
Thank you
Thank you
