Yaesu: Yaesu System 600/FT600
wcu02mpa
Asheville,NC
I have recently acquired a Yaesu System-600 HF transceiver. I do not have the unit in hand, but upon doing some reading, this radio uses one of three or four configuration keys to determine how the radio is used. I owned one these about 20 years ago, but literally cannot remember what these actually are. After some significant searching I cannot locate any information on what or where to get these, or even make them. Can someone enlighten me? I have a vertex VX-1700 that uses a jumper plug to enable the HAM bands. Is it anything similar to this?
AK9R
Staff member
Super Moderator
Central Indiana
Have you tried contacting Yaesu?
nerdplanet
You must remove the original key , its on the front panel , next to the clarifier , on the service manual its identified as CK-3, its a lego like thing on the front pannel , mine says FT-600 on it, it has a 3 spring loaded prongs behind it , shorting the 3 should give you full coverage mode , mine is working like that , has ITU marine channels , VFO mode , and 2 banks of channels that can be user programmed via front pannel . if memory doesnt fail to me , i shorted the 3 using a piece of aluminum foil tape behind the original key (which was configured as Land mobile).
mine after 8 years switched on , has developed a PLL unlock when cold. still can find someone that is worth sending around here in Chile.
wcu02mpa
Asheville,NC
I sent Yaesu a couple of emails An no response. Thanks for heads up. This one did have anything in the slot, not even a cover. I knew that going into it. It turns on, but would like to find the FT-600 key. In the meantime I will find a way to short the three pins. Thanks
nerdplanet
a trucker friend he put some steel wool on it , with a piece of electrical tape over it , at one time there were several Ft-600 and Vx1700 on the surplus market around here, i remember paying about 400usd for mine new in the box from a mining company that was switching to Codan radios, why not solder a wire behind the pannel and 3d print a key for the hole , did some buttons for my tm241 a few years ago.
