Yaesu System Fusion repeaters on the air
W9BU
Lead Wiki Manager
Super Moderator
Brownsburg, Indiana
#1
Let's use this thread to document Yaesu System Fusion repeaters that are on the air.
This thread is not for discussing pros and cons of Yaesu System Fusion as a digital voice format.
RBMTS
WA Database Admin
Redmond WA
#3
Redmond Washington
KC7IYE Repeater - Education Hill area
145.310 (minus offset)
103.5Hz Analog PL / 023 Digital
#4
145.170 WA2RES in Manchester NJ, Ocean County.
Running in AUTO/AUTO mode (analog PL 131.8 or digital on demand).
BETA unit from Yaesu.
n2hbx
Orlando, FL
#7
Orlando, FL Fusion
W4MCO 443.050+ running dual mode. Awaiting arrival of a second repeater.
103.5 PL in Analog mode.
Larry, N2HBX
AA9VI
#8
Can someone post a listing of which ones are actually linked or have Wires-X connectivity? I don't really see the use of a standalone system. I'm guessing there are others that feel this way too.
#9
None connected yet, as the current firmware doesn't support it. Apparently this is coming "soon", though.
avgas
Alberta
#13
Medicine Hat Amateur Radio Club
Medicine Hat, Alberta, Canada
VE6VVR
145.410- 100 hz CTCSS
Auto/Auto mode
#15
That repeater list above is nowhere near complete or up to date.
In Chattanooga, TN, Fusion in AMS mode is on 146.790.
Another Fusion repeater is going up on 444.100 soon, and the plan was to keep that just in C4FM digi mode.
Supposedly there is a system Fusion repeater in Cleveland, just outside of Chattanooga, but someone else will have to confirm that one.
BG..
W2GLD
Pinckney, Michigan U.S.A.
#17
I've got one on the air here in Southeast Michigan, more specifically, Pinckney, near Hell, Michigan.
W2GLD 442.675 MHz. +5.00 MHz. PL 141.3 Hz. or DSQ 001 (Pinckney, MI)
The repeater is always in Auto/Auto mode; however, WiRES-X is limited to digital only, as the analog side already has AllStar Link, IRLP, and EchoLink available for linking.
Also, there are two more on the air here in Livingston County, Michigan as well. In Howell, the Livingston County Amateur Radio Klub (W8LRK) has recented added a VHF and UHF System Fusion repeater as well.
W8LRK 146.680 MHz. -.600 kHz. PL 162.2 Hz. (Howell, MI)
W8LRK 444.525 MHz. +5.00 MHz. PL 100.0 Hz. (Howell, MI)
West Palm Beach, FL
#18
443.975 in Wellington, FL is on the air with a Fusion repeater. It is also linked to the Florida-wide SARNET (not digital). We will also be replacing our 147.045 repeater with a Fusion repeater in dual-mode soon.
John, K2CIB, Trustee
Palms West ARC
robertmac
#20
In the Calgary, Alberta area, the following repeaters are reported to have Fusion ability:
145.1100 VE6EIT Bragg Creek [analog as well]
146.6850 VE6CID
146.940 VE6RPT Cochrane analog and P25? [have heard digital on here but also may have been P25]
147.000 VE6HRA Alderysyde [have heard digital on this frequency] and analog
147.135 VE6GER Crossfield analog but is currently listed as Off-Air
444.000 VE6RYC [but not 146.85 which is also VE6RYC] analog as well
444.675 VE6FIL [have heard digital signal on this frequency] digital only
Other repeaters listed as having Fusion in Alberta
Medicine Hat frequency posted above
442.175 VA6ARD Red Deer/Pine Lake area.
