Hey all,
I was given a Yaesu VX-7R for passing my Technician examination back in March of this year. I recently was able to pick up a programming cable and found a great free program called VX-7 Commander.
After a little fiddling, I was successfully able to read and write to the radio. Unfortunately some of the frequencies programmed into the radio are not showing up. Now, I realize and notice that the VX-7 Commander software includes some software based mods such as opening up MARS, FRS, GMRS among a few.
I also believe that if I read and understand the owners manual correctly, the radio is capable of receiving transmissions from .5Mhz to 999Mhz. Above and beyond programming my local repeaters, I wanted to program in some defined frequency sets provided by the VX-7 Commander software, such as the CB spectrum, FRS/GMRS spectrum etc. Now the radio accepted the FRS/GMRS frequencies, including some local law enforcement frequencies for RX only.
Now, I have a couple of questions. First question is, how do I get the radio to show and use the 1.25 meter frequencies? I programmed my local 1.25 meter frequencies as I did with the 2 meter and 70 cm frequencies, yet only the 1.25 meter frequencies won't show up in the radio. When I turn the dial from channel to channel, the channels that house the 1.25 meter frequencies are skipped entirely, yet all of my 2 meter and 70 cm frequencies show up fine in the channel slot allocated.
My second question for now relates to programming RX frequencies into the radio. As I stated in the third paragraph, I programmed some RX frequencies into the radio and the radio accepted the FRS/GMRS frequencies, but not the CB frequencies. I'm going to assume because I have not enabled some software mods? I just assumed the radio can receive from .5MHz to 999MHz without the need to enable any mods, or am I missing something here?
Any help would be much appreciated. This is a fantastic little unit, and just want to use and enjoy as much as possible from it.
-Jason (KJ6VIP)
-Jason (KJ6VIP)
