Yaesu VX-8GR power
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Hey all,
I have a VX-8GR with the APRS option. I see at least one VX-8 in my APRS "earshot" that appears to be transmitting (at intervals, of course) 24/7, which implies the user got it to work off AC power. Whenever I try to run mine off the AC adapter (the NC-86B shown on Universal Radio's site), the power cuts out when it tries to TX the APRS beacon - leading me to believe it's drawing more power than it can supply through the adapter.
Does anyone know if there is a power supply for this radio which will let it run continuously? I haven't got the DC cable (EDC-5B or EDC-6) and I also just thought of one thing I haven't tried yet - not having the battery attached to the radio when I power it up.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
The wallwart definatly will not supply enough juice for full power transmit. Maybe enought for 0.5w Tx but not any power levels above that.
w2xq
Burlington County, NJ
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; DROID BIONIC Build/5.5.1_84_DBN-74) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
IMHO all the AC wallwarts for the VX-series are insufficient for transmitting at any power level. On my VX-5R, it really doesn't like receive either, inducing a hum on the audio. Perhaps the cleanest solution would be a second battery, and swap them out. HTH.
kayn1n32008
Sector 001
trsundstrom said:
IMHO all the AC wallwarts for the VX-series are insufficient for transmitting at any power level. On my VX-5R, it really doesn't like receive either, inducing a hum on the audio...
What he said but applied to icom as well. My Icom used to hum with a WW on receive. I have never tried with my FT-170 or FT-277, due to having a spare battery for each radio.
AK9R
Staff member
Super Moderator
Central Indiana
It's not an option. All VX-8GRs have APRS.
It's only an implication. You are assuming that the other guy is running his radio using the charger supplied with the radio. He may have hooked it up to a power supply using the E-DC-6 cable or something like it.
There are none listed in the owner's manual for the radio. Any regulated 12-16 volt power supply capable of delivering at least 2 amps should work through the E-DC-6 cable.
KZ9G
The standard chargers will not work this way. Now if you have the desktop drop in charger it usually works fine. This charger charges the battery itself and does not go through the radio to charge. The radio never sees the charger. I know of one ham that does this with his vx8.
