Pro-95
Output from YagiMax
Ok on the gamma correction ... I found a site where someone is matching without the gamma rod. http://www.clarc.org/Articles/uhf.htm
Pathetic photography but the picture does show a lack of gamma rod.
I find this interesting. Seems like a solid option for the lack of a gamma rod, even if it is at the cost of .5 DB. Not to mention that I don't have a gamma rod in the garage.
Is this similar to the J-pole and it's matching?
What do you think? Good idea/bad idea????
17DBi! :shock:CENTER FREQUENCY = 865 MHz
GAIN = 17.4 dBi
DRIVE IMPEDANCE = 200 OHMS (APPROX), WITH FOLDED DIPOLE D.E.
BOOM LENGTH:
REFLECTOR TO
LAST DIRECTOR = 6.86 FT = 82.4 IN. = 209.2 CM
TOTAL NUMBER OF ELEMENTS = 20
ELEMENT DIAMETERS:
DRIVEN ANY DIAMETER
PARASITIC = 0.031 IN. = 0.08 CM
A non-metallic boom is used
---OR---
Elements are mounted on insulators above or below a metal boom
with metal-to-metal spacing greater than the boom radius.
CUMULATIVE ELEMENT
SPACING LENGTH
CM IN. CM IN.
Ref Ref REFL ----------|---------- 16.53 6.51
7.49 2.95 D.E. =========|========= 16.36 6.44
10.31 4.06 D 1 --------|-------- 15.61 6.14
16.06 6.32 D 2 --------|-------- 15.48 6.09
23.52 9.26 D 3 --------|-------- 15.33 6.04
32.20 12.68 D 4 --------|-------- 15.19 5.98
41.81 16.46 D 5 --------|-------- 15.06 5.93
52.20 20.55 D 6 --------|-------- 14.95 5.89
63.23 24.89 D 7 --------|-------- 14.85 5.85
74.83 29.46 D 8 --------|-------- 14.76 5.81
86.93 34.22 D 9 --------|-------- 14.69 5.78
99.47 39.16 D 10 --------|-------- 14.62 5.75
112.41 44.26 D 11 --------|-------- 14.55 5.73
125.72 49.50 D 12 --------|-------- 14.50 5.71
139.37 54.87 D 13 --------|-------- 14.45 5.69
153.33 60.37 D 14 --------|-------- 14.40 5.67
167.29 65.86 D 15 --------|-------- 14.35 5.65
181.26 71.36 D 16 --------|-------- 14.31 5.63
195.22 76.86 D 17 --------|-------- 14.27 5.62
209.18 82.35 D 18 --------|-------- 14.23 5.60
