- Joined
- Nov 16, 2004
- Messages
- 2,085
Anyone else getting choppy audio on Yolo Sheriff Main 154.800 PL 141.3?
That's a channel I listen to all the time, but I do not program PL tones. The quality of what I receive depends on which scanner I am using and/or where that scanner is. My older PRO-10 & PRO-77 (crystal controlled) have no probs. My PRO-95s usually pick up just fine a well. But my PRO-97s do pick up all kinds of garbage - which I also usually blame on being near an emitting source. Sometimes I am able to eliminate the noise by switching on the attenuator.scannerboy02 said:Anyone else getting choppy audio on Yolo Sheriff Main 154.800 PL 141.3?
selgaran said:They switched to a system of simulcast transmitters recently, and it seems like they drift out of sync from time to time, which may be what you are hearing.
My cable modem puts out a nice dead carrier on that freq. Good thing I use CTCSS on all my scanners.gmclam said:The one frequency I get lots of background on is CHP Gold Base - 42.120.
According to the database, Mono County doesn't use PL on that frequency. You would think they would use it to reduce the interference.Exsmokey said:We pick this up in Mono County, believe it or not! Just south of the junction of U.S. 395 and CA 108 there is a stretch of highway on 395 of about 2 miles where it booms in and interferes with the Sheriff's Dept. in Mono County. They are also on 154.800
sacscan said:According to the database, Mono County doesn't use PL on that frequency. You would think they would use it to reduce the interference.
