BCD436HP: Zip Code Entry Question/ State Lines
Clearview, WA
#1
When entering a zip code (Oregon) to monitor that zip code and you are on the state line (for ex- Oregon and Idaho). will the scanner monitor the Idaho side?
For example, Ontario, OR (97914 Malheur County) and Payette, ID (83661- Payette County).
If not, how would you resolve this? Two favorites and scan each?
Newcastle, ON
#4
May not be in the right thread, I'm new to scanner and my BCD436HP can't set location anymore, everytime I try to setup my postal code location it say Out of Range......press any key. How to I get back this option.
PA
#5
Do you have the main database turned on? If you only have a favorite list turned on, and enter a location out of the area covered by the list, you will get an error.
Newcastle, ON
#6
Full database is on, I have turned ON and OFF stuff in my Nationwide systems and in Select lists to Monitor I have Full database ON....Search with scan ON....and Favorites ON.
phask
KZZV - SE Ohio
#9
You are probably doing it wrong - you do not TYPE in the numbers from the keyboard ,.0 but use the 6-9 keys to navigate.
All needed is the 3 letter code - I'm guessing L1B - works fine on my 536.
Newcastle, ON
#10
When I first bought it there was no problem entering my postal code and I was not using the keypad but the knob at the top.......I get the same message no matter what I do. If I enter the L I get the OUT OF RANGE right away.
