I have having some poor receive sensitivity with my new Bridgecom repeater system, and I'm trying to narrow down just where I might take some action to improve things. Beginning with the antenna system seems a good place to start.
The antenna is a monoband Comet CA-712EFC mounted on a roof tripod on a 10' mast. With the combined height of the roof the base of the 8' antenna is at 52' AGL. The feedline is 60' of new 1/2" Comscope heliax, which terminates in a new MFJ-270 Lightning Surge Protector (Gas) just outside my office/shack exterior wall. It is brought into the repeater with 6' of RG-213.
I've done a sweep of the entire antenna system with a Surecom SA-250 Antenna Analyzer. The lowest SWR is 1.09 @ 461.275 MHz. At the receive frequency of 467.675 MHz the SWR is 1.32 (see details in next image) :
Averages on a single frequency, 10 pass sweep are shown in the next image. The camera didn't focus too well for this image, but it should still be readable.
SWR 1.32
Zx 50.1 ohms
Rs 57.5
jX -28
The final image is at the transmit frequency of 462.675 MHz. This image is crystal clear so I won't transcribe the results. I cannot spot anything that stands out as a possible problem.
The last image is a composite trace of the duplexer. Note that the insertion loss at the receive frequency is -1.42 dB, which isn't all that bad! The reject of the transmit frequency isn't all that spectacular, but should be acceptable at -70.81 dB.
The transmitter is limited to 20 watts output in an attempt to better balance the system. It is capable of a full 50 watts continuous duty.
Range testing with a 4 watt Motorola XPR7550 shows full quieting at 1 mile, 70% quieting at 2 miles, but unreadable at 3 miles. With the antenna height and average 5' portable/mobile height, I should be seeing around 10 miles for 70% HT coverage by my calculations.
Does anyone have any suggestions as to where next to look?
SWR 1.32
Zx 50.1 ohms
Rs 57.5
jX -28
