Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 12-04-2008, 12:07 AM
Default Unitrunker stops decoding DC's 800 MHz system
Just downloaded the latest version of Unitrunker and it works great. Kudos to the development team for providing such top-notch software.
It operates as expected with one exception.
Washington, D.C. has two systems with the same Motorola system ID. One system is UHF, and the other is 800 MHz.
Unitrunker decodes the UHF system fine.
When I switch control channels to the 800 MHz system, it decodes for a few seconds. Then it stops showing talkgroup/channel activity. However, the signal level continues to fluctuate but stays consistently good (99% to 100% range typically).
If I exit and restart, it may start showing talkgroup/channel data again for a few seconds, then it stops, again.
Switching to other 800 MHz systems, they decode fine, even with weaker signal levels.
Any ideas?
BillLayton
Old 12-06-2008, 08:36 PM
Seņor Member
Hi Bill;
What system is this?
Old 12-07-2008, 05:24 PM
Dewey's Avatar
Send a message via ICQ to Dewey Send a message via AIM to Dewey Send a message via MSN to Dewey Send a message via Yahoo to Dewey
Originally Posted by Unitrunker View Post
Hi Bill;
While I haven't seen the problem yet, I believe it's the 603d system on the 800 side.
Dewey
Old 12-09-2008, 12:17 AM
Seņor Member
Thanks Dewey. I looked at the system in the DB. I don't see anything special there. The program should work fine. I'll just sit back and wait for Bill to volunteer more information.
Old 12-09-2008, 07:07 AM
Dewey's Avatar
I have been checking this from Southern Maryland (DC suburbs) this morning, and so far so good. I have not yet experienced any stoppages, but I will continue to monitor. I don't know if it makes a difference, but I've always closed Unitrunker (and Trunker) down prior to switching systems to give it a fresh start. I remember that not doing so would cause problems in one of the older versions. Also as an FYI, I'm running from a tapped Pro-96 into a Toshiba Pentium M laptop.
Dewey
Old 12-12-2008, 07:27 PM
Dewey's Avatar
Just an update to my 12/9 post on monitoring 603d. I ran UT continuously for 4 hours without incident before having to go to the real job. My primary system is a Toshiba Pentium M laptop running Windoze XP Home, SP2. I will also sometimes run it on my Toshiba T8100 laptop running Windoze Vista Home Premium, SP1.
Dewey
Similar Threads
San Antonio EDACS system and the press blantonl Texas Radio Discussion Forum 8 05-03-2009 11:53 AM
West Tennessee Communications (800 MHz) System question? semo Tennessee Radio Discussion Forum 7 06-25-2008 01:34 AM
Okay, this is probably going to be a stupid question, but..... SouthSideScannerGuy General Scanning Forum 18 02-25-2008 01:06 PM
Buchanan County Public Safety - 800 MHz System Thunderbolt Missouri Radio Discussion Forum 0 06-17-2007 01:10 PM
Nevada Statewide Radio System - News and discoveries Pro-95 Nevada Radio Discussion Forum 6 08-06-2004 05:09 PM
