Can't Get UniTrunker to Tune Output (voice) Radio
I am using UniTrunker to successfully monitor and decode the CC of a local EDACS system. All frequencies are programmed in LCN order, and talkgroups are popping up as they are being decoded.
I have a Pro2006 with an Opto board installed. At one time I was able to successfully tune this radio with UT by way of a serial cable (with serial-USB adpater). For some reason, I am unable to get UT to take control of the Opto.
In the radio configuration for OPTO, I have it online (Running), and the COM port matches that with what Windows has identified the cable on. I have changed the priority on the talkgroups to 1 and checked Listen for each.
Any advice?
