Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 03-12-2009, 7:07 PM
Forts's Avatar
Mentor
Default MotoTRBO?
With the growing popularity of MotoTRBO does anyone know if it would be possible to have an application such as UniTrunker to track calls and users? (UniTRBO? ) Or would it be impractical to extract this type of data from TRBO transmissions.
Old 03-12-2009, 9:56 PM
VE3JSO's Avatar
from what i heard they are working on the possiblity to track mototrbo but it won't come out for a year or two
Old 03-13-2009, 12:14 AM
Such applications decode the control channel of a trunking system and can use a scanner for recpetion of the control channel. MotoTRBO is not a trunking system and uses no control channel to track off of and you would need a MotoTRBO radio to receive. This is not to say that something won't be developed but first you would need a MotoTRBO radio to start with and already know the frequencies involved before hand.
fineshot1
NJ USA
Old 03-13-2009, 1:09 AM
Seņor Member
TRBO is based on a published EAI standard. The standard includes trunking capabilities but not all TRBO systems use trunking. This is very possible but not something I personally have time for at the moment. I suspect that may slowly change as the format becomes more popular. The GNU radio folks might also be working on this.
Old 03-13-2009, 10:18 AM
N_Jay's Avatar
Not Posting
Hmmm, maybe a ETSI standard?
Old 03-13-2009, 12:08 PM
Texas DB Admin
Isn't MOTOTRBO simply 2 slot TDMA. Similar to OpenSky and P25 Phase II? At some point won't it be necessary for scanners to demod/decode 2 and 4 slot TDMA?
Russell
Old 03-13-2009, 1:42 PM
N_Jay's Avatar
Not Posting
Russell
Saying "2 slot TDMA" is about as specific as saying "AC Electric circuit", or "Round Rubber Tire".
There are more unanswered important factors than provided information.
P25 Phase 2, OpenSky (even the two slot) and MotoTrbo are as much different as they are the same.
A receiver would have to be DESIGN SPECIFICALLY to receive each.
Old 03-13-2009, 7:42 PM
Forts's Avatar
Mentor
Thanks for the input folks. I realize TRBO, as it is now, isn't a trunking protocol which would fall into the 'trunking decoder' software realm, but each transmission does contain packets detailing caller ID, group ID etc etc which can hopefully be extracted someday and provide a little detail on the transmissions. At least something to hold us over until the first TRBO scanners
Old 03-13-2009, 8:26 PM
BamaScan's Avatar
I have heard that TRBO can have multiple conversations going on at the same time on one frequency. Looks like it would be hard to decode this. I hope someone can break the code and get a scanner on the market soon. My whole county will soon be TRBO.
Old 03-13-2009, 9:59 PM
n2hbx's Avatar
Default MotoTRBO Tricks
Yep, not only can you have 2 digital conversations going on at the same time, through the same repeater (tnx to the 2 time slots), but you can have one T/S doing digital voice and the other doing digital data (128K). You can also network repeaters together over the internet, so you can have one T/S for local area comms and the other one for wide-area linked use. We have a few customers that are very interested in this application.
Lots more cool applications are coming down the pike.
Editorial opinion: I doubt you will see much interest in the scanner manufacturing community to develop a MotoTRBO tracking scanner unless there is a HUGE influx of Public Safety entities going to it.
Larry
So Many People To Annoy...
So Little Time.
Old 03-13-2009, 11:50 PM
N_Jay's Avatar
Not Posting
Larry
128K? I don't think so.
The interface may be 128k, but over the air will be about 4.8k max.
Old 03-14-2009, 2:09 PM
NeFire242's Avatar
Not as hard as you'd think, look at all the data that passes over a control channel, and you have multiple conversations and data at the same time.
Old 03-20-2009, 10:35 PM
Liverdog's Avatar
...The GNU radio folks might also be working on this.
Rick, who are these folks?
Old 03-22-2009, 9:29 PM
Seņor Member
GNU Radio is an open source software / hardware project.
Old 03-23-2009, 10:20 AM
scanlist's Avatar
This MRT/Urgentcomm article may be of interest on this thread.
Motorola adds to P25, MOTOTRBO portfolios | ASTRO 25 Express | IP Site Connect | Capacity Plus | CP185 - Urgent Communications article
There is a MotoTRBO "Capacity Plus" wide coverage VHF PMR trunked system licensed as WQBQ701 on the air covering the Denver area.
Old 03-23-2009, 12:43 PM
Forts's Avatar
Mentor
Great.... more TRBO options for them to push out there
Old 03-23-2009, 10:55 PM
WayneH's Avatar
Forums Veteran
You want that; think of it like economics 101. The greater the interest the sooner it comes to market (for us).
PM's are permitted by contact list only. Please use direct email for all other contact.
Please follow the forum rules and contact a moderator directly, not via a thread.
Old 03-24-2009, 7:42 AM
Forts's Avatar
Mentor
Actually, yes... That's a good point. Didn't look at it from that angle.
Old 03-26-2009, 4:44 PM
TRBO is not trunking. But they will have a system out in 2011.
Old 03-28-2009, 5:05 AM
WayneH's Avatar
Forums Veteran
The discussion on MOTOTRBO Trunking has been split off to http://www.radioreference.com/forums...-trunking.html
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
