Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 05-27-2009, 01:51 PM
Red face Help CC Data Read
Unsure if this is the right place for this thread but I am looking for some help with the following...
I am looking for someone to help me in setting up a scanner to decode the CC on the 800 mhz trunk system'.
If anyone knows of someone who can assist me with this and someone who can be trusted to set this up for me I would appreciate it. I know there are some risk' due to modification of the scanner, etc.
PM's wlecome.
Thanx.
Old 05-27-2009, 04:11 PM
davidbond21's Avatar
Send a message via ICQ to davidbond21
It's actually not all that difficult to do on the software side, seeing as there are many excellent programs available to do this for free( I use Unitrunker personally, but there are others that work just as well or better depending on who you talk to).
What kind of scanner do you plan on using? Since you're more than likely talking about the Austin/Travis County P25 system, I assume you have a digital scanner. Depending on what it is, you may or may not have to add a discriminator tap since many of the newer digital scanners have them built in.
(+)-3-methoxy-17-methyl-(9α,13α,14α)-morphinan
BC350C, IC-R7000, PRO-95, PRO-96, PRO-197, PSR-500
FT-7800R, Racal 25's, LPE-200's, Jaguar 725M
Old 05-27-2009, 09:25 PM
BaLa's Avatar
Send a message via ICQ to BaLa Send a message via Yahoo to BaLa
if you have a pro-96 you can use Pro96Com on the CC.
VFB Stuttgart Deutscher Meister 2006/2007
Uniden BCD396T
RS Pro 92(b), 95, 96
Kenwood TK-280 (146-174MHz)
Old 05-27-2009, 10:01 PM
Red face
I plan to use a new 396XT or use the 996XT [when it is for sale]. I have heard about how you have to run some wire to make it all conect but if there is an easier way to do this to avoid bricking a radio that would be best.
Are the Uniden's the way to go or is there a better scanner/software to use? And what sort of software should I use with the Uniden's/or other radio? Also, what sort of computer to run it, memory, Windows XP, etc?
Appreciate the help. I am looking forward to doing this. Seems like and interesting way of learning about these types of systems.
Thanx.
Old 05-27-2009, 10:21 PM
OH/WV DB Admin
Send a message via MSN to mtindor
Thanx.
With the Uniden 396XT and 996XT as well as the GRE PSR-500/600 and Radio Shack PRO-106/197 you don't need a physical discriminator tap. Those scanners decode the CC data and dump the data over the PC/IF port directly into software that supports it (Unitrunker, Trunk88, perhaps Pro96Com and some others).
So if you're going to get a Uniden XT model, you won't have to risk damage to your scanner just to be able to decode. You'll be all set. All you need is a free serial port on your computer and a trunking program to capture the decode data and present it to you.
XP / Vista are fine. Some of the different software is mentioned above. Check out the RR Wiki for more info on various software.
* Note: Not ALL of the software listed in the Wiki will work using the PC/IF output. Some of that software requires a discriminator tap or/and a data slicer. Specific software that I personally know of that will work with the XTs are Unitrunker and Trunk88. There may be others, but I can't say for sure what they are.
Similar Threads
To CC Only or Not to CC Only? shootinnews Utah Radio Discussion Forum 5 11-18-2008 09:30 AM
Forum marked as read error wlmr System-wide Administration 5 09-10-2008 09:23 AM
System not working? Load more frequencies... troymail GRE Scanners 7 11-05-2007 10:55 AM
best frequency for mid range data transmission cworldspin General Scanning Forum 6 09-13-2007 04:19 AM
Trunking Protocols MaxTracker System Administration and Maintenance 3 01-25-2005 04:31 PM
