Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 06-03-2009, 11:28 PM
ac7xc's Avatar
Send a message via AIM to ac7xc Send a message via Yahoo to ac7xc
Question Unitrunker on Vista 32 bit
I just installed Unitrunker on my Vista 32 bit machine after use DOS Trunker for years. I am having a few problems with the program that I hope someone can help me solve.
1. My quality is from 99% to 100% but next to that I am getting the message recording error. What does that mean?
2. Where are the log files saved? I have saved the settings for Unitrunker and when I restart it the settings are saved, but I don't know where the log files are. I checked in rfmobile\unitrunker and there is nothing and a quick check of the application data files and directories showed nothing related to the program.
3. The local MOT II TRS has rebanded and I need to set up a table for it Unitrunker.
Thanks for any help,
Keith
____________________
Best Regards, Keith http://home.comcast.net/~kilowattradio/
BCT15X PRO-106 PRO-92 PRO-83 TH-F6A FT897D BC346XT BC245XLT
Mac OS X, WIn7 & Linux
Old 06-04-2009, 05:35 AM
tag21's Avatar
Umm Keith, that screen shot shows the old (DOS) based Trunker, but you are saying you have installed Unitrunker?
Which file did you download from the Unitrunker web site? If you want the windows version, don't download the one with 'Retro' in the title. You need the one called UniversalTrunker.zip dated October 2008.
See how that goes.
Old 06-04-2009, 09:00 PM
Seņor Member
I've never seen a good decode rate combined with this error message. Try pressing the refresh key (F1 or F5 - I forget) to clear up the display.
Old 06-05-2009, 12:30 AM
ac7xc's Avatar
It turns out that tag21 was correct I had an old version Unitrunker installed and now the log files are appearing and the error message is gone. Now I need to figure out how to change the tables for trunked systems that are rebanding or is that in the source code?
Tags
decoding, errors, unitrunker, vista
Similar Threads
20-147 Cable, Pro-95, and Vista JohnSc1 Scanner Programming Software 5 06-03-2009 11:40 PM
UniTrunker and Re-Banding KT7L Utah Radio Discussion Forum 42 06-18-2008 04:17 PM
Layman terms Jono40141 Trunking Control Channel Decoding 9 01-26-2008 01:25 AM
Help - Weird Unitrunker problem wwhitby Trunking Control Channel Decoding 6 11-14-2007 06:41 PM
FT: Pro-99 and etrex vista GPS kg4omx Old Classifieds Archives 0 11-30-2005 07:41 AM
