Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 06-21-2009, 01:35 AM
Default Older scanner controlling PSR500 with unitrunker
I am trying to Use a old PRO 25 for CC and a PSR-500 for voice. I have had no success. I have the pro-25 hooked up to my soundcard using a DISC. tap. And PSR 500 using USB cable. I can see Data using Unitrunker Retro But this gives me no data From RR as far as Talkgroups. This is no good to me, for I am trying to indentify talkgroups not listed in the database. Is there anyway to use these two scanners for what I am trying to accomplish in the newer version of unitrunker and if not what can I do?
Old 06-23-2009, 08:57 PM
Seņor Member
Originally Posted by Drumnjim View Post
I am trying to Use a old PRO 25 for CC and a PSR-500 for voice. I have had no success. I have the pro-25 hooked up to my soundcard using a DISC. tap. And PSR 500 using USB cable. I can see Data using Unitrunker Retro But this gives me no data From RR as far as Talkgroups. This is no good to me, for I am trying to identify talkgroups not listed in the database. Is there anyway to use these two scanners for what I am trying to accomplish in the newer version of unitrunker and if not what can I do?
I suggest leaving the PSR500 disconnected while you get the PRO25 working with Unitrunker. Get decoding to work first and then add voice.
Similar Threads
Great scanner....Finally!! k9xyz GRE Scanners 7 05-17-2009 04:11 PM
Anyone have a PSR500 Scanner? planetboy Western Canada Radio Discussion Forum 4 05-01-2009 10:32 AM
Layman terms Jono40141 Trunking Control Channel Decoding 9 01-26-2008 01:25 AM
pro96com - controlling Uniden Scanner swmichiganradio Trunking Control Channel Decoding 1 09-20-2004 05:53 PM
help with older scanner stevestephens Florida Radio Discussion Forum 3 08-08-2004 09:03 PM
