Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 06-30-2009, 10:15 PM
Default Trunk88 No Joy
I tried t88 versions 4.79 and 4.80 on my BC396xt-Uniden USB cord, switched USB ports&drivers around.
I can run Freescan with the same settings with no problem why not T88? I'm thinking about just giving up on this!
Old 07-01-2009, 02:00 AM
K8TEK's Avatar
Send a message via AIM to K8TEK Send a message via Yahoo to K8TEK Send a message via Skype™ to K8TEK
Where did you get ver 4.80?
RIM 9630|Motorola E815|Samsung SCH-U740|Motorola T730|Motorola i355|A girlfriend|Motorola V120c|Kenwood DPX501|
Old 07-01-2009, 01:59 PM
DDan's Avatar
You have to configure the scanner to output the CC data on the serial port. Settings > Set C-Ch output.
73 de Dan/w6kru
Yaesu FT-857 FT-90 VX-170 VX-3
BCD396XT BCD396T PRO-90 PRO-2050
Base RS 20-176 / Maxrad MFB8133 & MYA8256
Mobile Maxrad MUF8043
http://dansracephotos.com
Old 07-03-2009, 07:59 PM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Send a message via AIM to KE4ZNR Send a message via Skype™ to KE4ZNR
Arrow
Also make sure to do the following:
1) Go to wherever you have your Trunk88 folder.
2) Open up "TRUNK88.CTL" in notepad.
3) Make sure under settings that CC Data Serial Port = # matches up with whatever port you have your cable plugged into on your computer.
4) Save "TRUNK88.CTL" with needed changes.
This should get you started.
Happy Monitoring!
Marshall
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
Similar Threads
Trunk88 coolguy Trunking Control Channel Decoding 6 02-01-2009 08:51 PM
Trunk88 coolguy Trunking Control Channel Decoding 2 01-05-2009 08:58 PM
TRUNK88 Radio ID's coolguy Eastern Canada Radio Discussion Forum 7 01-03-2009 08:09 PM
Trunk88 coolguy Eastern Canada Radio Discussion Forum 28 11-15-2008 06:26 PM
Trunk88 coolguy Eastern Canada Radio Discussion Forum 6 10-23-2008 01:06 PM
