Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 07-10-2009, 07:46 PM
DickH's Avatar
Default UHF Trunking
Does anyone know the channel nymbers for 453-454MHz and 460-461MHz with 6.25kHz spacing?
Old 07-10-2009, 08:58 PM
Seņor Member
Do you want P25 or Motorola channel numbers? The base and offset are chosen by each system's administrator. There is no standard table.
Old 07-10-2009, 11:05 PM
DickH's Avatar
It's an analog Motorola system in Umatilla, Oregon. The Base Spacing and Offset are in the RR database, but the spacing is 6.25kHz and some scanners will not accept that spacing. We've tried 12.5kHz but it won't work.
If we know the channel numbers we may be able to work around the problem.
Thanks for your help.
Old 07-11-2009, 03:12 PM
Seņor Member
That is unfortunate.
Calculate the LCN / frequency pairs yourself using a spreadsheet program like Excel.
F = Base + (LCN - Offset) * Spacing
Be sure Base and Spacing are in the same units (eg. don't mix kHz with Mhz).
Old 07-11-2009, 07:41 PM
DickH's Avatar
I'd like to know the LCN for 453.00000, 453.00625, 453.01250, 460.00000, 460.00625, & 460.01250 - OR - where can I find them?
Old 07-11-2009, 08:45 PM
Seņor Member
Remember algebra?
LCN = Offset + (Frequency - Base) / Spacing
The first table reads
Offset = 380
Base = 453.0125
Spacing = 6.25 kHz which also equals 0.00625 Mhz
A base of 453.0125 implies no channels on the system with a lower frequency. Using a few published frequencies from the DB as examples: 453.1 Mhz, 460.1 Mhz and 460.6 Mhz.
For 453.1 Mhz, solving for the LCN is ...
Offset + (453.1000 - Base) / Spacing =
Offset + (453.1000 - 453.0125) / Spacing =
Offset + 0.0875 / 0.00625 =
Offset + 14 =
380 + 14 = 394.
So the channel number of 453.1 Mhz is 394.
The second table reads
Offset = 380
Base = 460.0000
Crunching 460.1 through the same formula (but with the second table) yields 536 + 16 = 552.
Crunching 460.6 through the above formula yields 536 + 96 = 632.
All of this assumes (a) the published band plan is correct and (b) the published frequencies are correct.
Old 07-12-2009, 12:17 AM
DickH's Avatar
Remember algebra?
Could you after not using it for 50 years?
Offset = 380
Base = 453.0125
Offset + 14 =
380 + 14 = 394.
Offset = 380
Base = 460.0000
Thanks very much.
Old 07-14-2009, 04:13 PM
wayne_h's Avatar
Forums Manager
Send a message via AIM to wayne_h
Try my spreadsheet out. Link. Use the first tab and enter the known details. It will list all the "LCNs" for the useable freqs.
-Wayne
Please contact me via email for a faster response.
Forum Rules and Guidelines
Similar Threads
UHF Motorola Astro Saber III UHF maxtracs VHF spectra VHF Kenwood 270G Grog Old Classifieds Archives 22 02-16-2009 12:41 AM
FS-Regency UHF 10 CHANNEL Programable mobile W9NES Old Classifieds Archives 2 04-20-2008 11:22 AM
Got my 796D working on UHF Digital Trunking kd8ega Uniden Scanners 1 12-22-2006 04:02 PM
796D uhf trunking question kd8ega Uniden Scanners 4 12-17-2006 11:31 PM
