Tony,
You've choosen an excellent program.
Before you do anything play it safe and make a backup copy of your TRUNK88 files.
With TRUNK88 up and running enter [S]ystem in the command field. Then enter [E]dit in the system command field. Then enter [B]ackground & colors in the parameter group field.
Using your keyboard DOWN arrow, scroll down past colors 0 through 15 until you see AREA #1. Your cursor will be flashing in the color field and a color pallet will appear at the bottom of the screen.
I would suggest at this point you enter Ctrl-H. This will bring up a help file that explains what the different AREA's cover. If memory serves me correctly the area you 're looking to change is AREA# 4.
When you're ready to start select the AREA(S) of you choosing. Pick a color of your choosing and enter its numeric number then hit the DOWN arrow to select it (Hitting the ENTER key will act like the tab and move you to the right). Do Ctrl-R and your new color choice will appear in the respective area changed.
I would also suggest that you only do one AREA at a time so you'll know what section of TRUNK88's display was changed so you can make another color choice if you didn't like a color selection applied.
Good luck.
Dennis
