Hi Dave,
Try running windows in Safe Mode, or booting in MS-DOS (not a command line window).
I built the slicer and had little to no SLICER.EXE activity no matter what I tried. After going through everything with a continuity tester with no obvious problems and being totally stumped, I read online that some RS-232 serial port driven programs can conflict with software drivers on your computer (usually when more than one piece of software is trying to access the port at once), and to boot in MS-DOS to be absolutely sure. Not being savvy enough to do so, I crossed my fingers and hoped Windows Safe Mode would suffice, and it did!
If that doesn't work, I would be much more convinced that the problem lies in the slicer hardware.
I also agree that there is high demand for a windows sound card input Passport & Multinet program(s). While I have yet to run into any Multinet, Passport is significantly popular here on the west coast. Realistically we just need to make the first part (sound card low-pass filtering and decoding) of Slicerwizard's LTR-Analyzer talk to the second part (database of multinet & passport OSW commands and trunker style interface) of Eric Cottrel's LTR Dump/LTR Trunk programs and then make it all run on Windows XP and Vista! Ideally a new program could be created from scratch.
I had a blast a year or so ago posting on the forums here about trying to identify lesser-known Passport OSWs (unsupported by Eric's programs) taken from my LTR Dump log file. As much as I want to learn C++ and I would love the excuse to try and make a working program for this, I wouldn't know where to start and would be way out of my league ("Take an audio signal, filter out everything above a specified frequency and then chop it into bits of data" isn't exactly the title of a chapter in one of those 'Teach yourself a programming language' books!).
To you few guys with the necessary electrical engineering and computer science knowledge to do it, let us mere mortals know if there's anything we can do to convince you to take on the project - be it financial donations or just channeling large quantities of good will in your direction.
Regards,
Inigo
