Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 08-14-2009, 02:29 PM
Forts's Avatar
Send a message via ICQ to Forts
Default UniTrunker Retro Bug?
I realize there is no ongoing support for UT Retro but I just wanted to mention what would appear to be a bug (in case someone else is seeing the same thing).
I've been monitor a local EDACS system and I wanted to get a better idea of what talkgroups are in use on a daily basis. I moved my .gid file out of the folder so a new blank one would be created. After about a day and a half of running now, a handful of the talkgroups show different months in 2008 under the FIRST column (which obviously isn't the case). I normally use the LAST column while checking for activity but the first time the group was seen can be a handy tool as well.
On a somewhat related topic, and guesses on the ETA for the next UT release?
Pro-106 - Pro-96 - BCT15 - BC780XLT - Pro-433 - Pro-2045 - BC-350 - Pro-43
Old 08-14-2009, 02:48 PM
OH/WV DB Admin
Send a message via MSN to mtindor
I never noticed that.. then again I was never looking. I'm not sure if it would be categorized as a bug or not. I'll try and duplicate that a litte later and let you know if I experience the same thing.
As far as a guess... half past a monkey's @ss and quarter to...well you know what heh.
Old 08-15-2009, 06:59 PM
Seņor Member
Was the program running while you did this?
Old 08-15-2009, 07:45 PM
Forts's Avatar
No it wasn't. I shut it down, moved my existing .gid file out of my UT folder then restarted.
Old 08-15-2009, 09:04 PM
Seņor Member
Do you have any trunker data files in that folder?
Old 08-16-2009, 08:38 AM
Forts's Avatar
No I do not.... I'll try it again today with a fresh install of UT Retro in a new folder.
Similar Threads
Sticky Thread For MilAir IV TinEar Maryland Radio Discussion Forum 5138 Today 06:18 PM
Why I stopped using Unitrunker K8TEK Trunking Control Channel Decoding 8 05-21-2009 09:50 AM
Sticky Thread for MilAir III TinEar Maryland Radio Discussion Forum 5266 01-20-2009 02:02 PM
UniTrunker retro ? ronenp Trunking Control Channel Decoding 4 01-13-2009 12:04 AM
Can anyone help me with Unitrunker setup/install? W4UVV Trunking Control Channel Decoding 9 07-06-2008 08:59 PM
