Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 09-01-2009, 04:57 PM
Careful, I CAN hear you!
Send a message via MSN to milf Send a message via Yahoo to milf
Default Prfo96Com & SOAP issues
Apparently the fun continues with our new SOAP interface... Tried dling the AWIN to Pro96Com and got this error msg... (See attachment)
Admin for AR, LA, MS, and TN
*RS PRO-96, RS PRO-92B, BC855XLT*
"Did I say something funny meow?"
"If a tree falls, do the squirrels get FEMA trailers?"
Old 09-01-2009, 05:04 PM
mikey60's Avatar
Pro96Com has used the SOAP interface for nearly a year, so it shouldn't be an issue that just appeared. I don't have the same issue on the MPSCS, but I'll test a bit more and release an update if I find a problem.
http://www.psredit.com
Old 09-01-2009, 05:14 PM
Just retried and it worked fine... Dunno... seems to be a lot of strange issues that popup then go away.... maybe a SOAP poltergiest???
Old 09-01-2009, 08:10 PM
mikey60's Avatar
I need to update to the latest SOAP anyway, not that it adds too much that Pro96Com uses.
Similar Threads
Issues with SOAP Web Service jeff2674 Scanner Programming Software 7 08-31-2009 05:54 PM
SOAP - Type Mismatch error jeff2674 Database Discussion Forum 1 08-13-2009 10:06 PM
PSR-300 Overload issues CStarr59 GRE Scanners 11 01-02-2009 06:46 PM
Connecticut Departments (PD/FD/EMS) with Radio Issues joetnymedic Connecticut Radio Discussion Forum 3 05-17-2008 11:23 AM
