Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 09-01-2009, 07:20 PM
Default Trunking Monitor S/w
Does anyone know a good windows based Trucking decoder software ? I have used trunker for years and wanted to try to get away from the dos based software. Thanks Bob
The software will be used to monitor a type II smart zone 800 MHz system
Xts5000 Model 3 With encrpt
Astro Spectras
Old 09-01-2009, 07:44 PM
Wiki Admin
See the links in this article (blue text is a link) - to a certain extent, it varies depending on what scanner you are using...
Trunked Radio Decoders - The RadioReference Wiki
73 Mike
Old 09-01-2009, 09:03 PM
Thanks, Now i'm using a mcs2000 with a slicer.
Astro Spectras
Old 09-02-2009, 02:05 AM
joescanner's Avatar
Just another radio geek.
Lose the slicer and use audio decoding. You still need the baseband audio out but the decoding is 100% more reliable (in my own experience) with the audio decoders as opposed to the slicer/serial decoders.
Joseph Stein, KD7MLG
RadioReference Database Administrator for Oregon and Washington State
Old 09-02-2009, 10:09 PM
ve3tej's Avatar
Send a message via MSN to ve3tej
Trunk88 is one of the best software out there for decoding Motorola systems. There is a yahoo group for support and the software can be downloaded here.
Index of /~phoenix/wap/TRUNK88
Old 09-05-2009, 08:29 AM
That radio should be able to directly drive a sound card line input. Just make yourself a shielded cable.
Sound card based decoders can do a far better job than slicers (e.g. filter noise and compensate for non-linear responses, etc.) if the audio is properly coupled to the PC's audio input.
A direct connection (or the near direct connection that a 10k resistor provides) from a tap point to a mic input will overdrive the PC's audio stages and reduce the effectiveness of filtering software. Lack of a DC blocker putting mic driver voltage back into the scanner is another no-no.
A direct connection from a tap point to a PC's line input can put an excessive (600 ohm) load on a scanner's audio detector stage and lead to signal distortion. The high load pretty much guarantees that there will be poor low frequency response issues.
With simple two level signals (like Moto 3600 bps CCs), mediocre audio coupling generally isn't a problem as long as you're monitoring strong local signals. But when the static and other noises increase, a dicey audio link will surely lead to lower than necessary decoding rates.
Similar Threads
New to scanners and trunking JWTL General Scanning Forum 3 05-16-2007 05:19 PM
New to trunking and scanners JWTL Trunking Forum 1 05-16-2007 05:18 PM
New to trunking - PLEASE HELP!! nopicowboy Kentucky Radio Discussion Forum 4 10-29-2005 10:52 PM
939.4250 NFM Trunking CC??? whooey General Scanning Forum 2 07-22-2005 07:25 PM
BC246T Trunking Not Working (ONLY), Very Odd Condition! ppmd Uniden Scanners 9 07-13-2005 01:42 AM
