Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 09-10-2009, 09:02 AM
Caesar's Avatar
Send a message via ICQ to Caesar Send a message via AIM to Caesar
Default T88 questions
I am sure it is somewhere in the help or here on the forum but I can not locate it at either location yet.
after the TGID it usually has A, D, or 8. I understand those but sometimes it will show 2 , does that mean it is a patch? or what is it showing?
Also under the PrBK it shows U which is the bank mine is defaulted with but before that it usually shows P or 50, what is the difference and i never see a number other than 50, is it not reading the priorities or are all the priorities on my system set for 50? it is a Moto IIi system.
and lastly the size colum examples are:
9 (5)
25 (12)
11 (11)
etc etc
on the far right side where it shows the data stream, what are the difference between the 3 rows of dashes going up the screen, and when the letters/numbers say FRAMING does that mean my signal has dropped/bad data recv'd or something different? it will sometimes do it after I have been on the system with solid signal for a while.
it is a great program but these are a few things i haven't figured out yet.
Thanks,
Caesar
Uniden: BCD396T, BR330T & BCT-15 (x3)
Icom: IC-91AD & ID-800H (D-Star)
Yaesu:FT-857D
Radio Shack: Pro-163 & Pro-197
Heathkit: HA-10 (1KW Amplifier)
DV Dongle
Old 09-10-2009, 09:03 AM
Caesar's Avatar
ah one more, sometimes it will start beeping and i check the screen and one of the freq shows BSI ??
Yaesu:FT-857D
DV Dongle
Old 09-10-2009, 01:08 PM
// Type II call modifiers
// 0 normal call
// 1 Multigroup
// 2 Emergency
// 3 Patched
// 4 Emergency Patched
// 5 Emergency Multigroup
// 6 invalid
// 7 Multiselect
// 8 Encrypted
// 9 Encrypted Multigroup
// 10 Encrypted Emergency
// 11 Encrypted Patched
// 12 Encrypted Emergency Patched
// 13 Encrypted Emergency Multigroup
// 14 invalid
// 15 Encrypted Multiselect
PR = Priority. Those are the priorities that you set for talkgroups and radios. Only relevant if you use TRUNK88 to control a second scanner.
9 (5)
25 (12)
11 (11)
etc etc
From the help text:
[ Talkgroup Size ]
These parameters control the screen location and foreground (text) color of the
Talkgroup Size values that are displayed during group calls. The first value
displayed is the total number of radio IDs active on a talkgroup; it includes RIDs
seen affiliating and/or PTTing on the group. On non-networked systems, the second
value displayed is the number of RIDs seen affiliating only (e.g. lurking) on the
talkgroup. On multi-zone SmartZone and OmniLink systems, the second value is the
number of RIDs seen affiliating to the talkgroup on the current zone/site (e.g. how
many radios dragged the call over to the site). For patched/MSEL'd calls, the values
are the totals for all member talkgroups. To determine which RIDs are active on a
talkgroup, patch or MSEL, use the Edit Talkgroup command to load the record of
interest and then press Ctrl-A to display a detailed list. Consult the Ctrl-A hotkey
help text for more details. The recommended Width value for the Talkgroup Size
display is 6; this provides enough room for an nn(nn) display. Set Width to zero to
suppress the display of this field.
From left to right - input audio volume level, current decoding accuracy, number of pending commands.
Yes. Each Bad or Framing display represents a lost OSW.
Something has caused the loss - perhaps a noise burst.
Base Staion Identifier. The system is broadcasting its callsign, as required by law.
Old 09-10-2009, 01:54 PM
Caesar's Avatar
wow, thanks for ALL the answers! :-)
one other questions, the 3rd row is pending commands.... what kind of commands?
Yaesu:FT-857D
DV Dongle
Old 09-10-2009, 05:17 PM
Careful, I CAN hear you!
Send a message via MSN to milf Send a message via Yahoo to milf
Commands sent to the system for various reasons and waiting for que to take effect.. such affiliate/patch/I-call/paging/go secure, etc... The busier the system is, the more pending commands you will notice.
Admin for AR, LA, MS, and TN
*RS PRO-96, RS PRO-92B, BC855XLT*
"Did I say something funny meow?"
"If a tree falls, do the squirrels get FEMA trailers?"
Old 09-10-2009, 06:48 PM
Caesar's Avatar
ok cool, I have noticed the one that shows 2 "emergency" is showing up on the COntrol Channel/Data and I noticed the message Channel 1 RIB Enabled. i assume this means system control or someone is working on/with the system? also saw Channel 2 RIB Enabled and then CHannel 2 RIB malfunction
Yaesu:FT-857D
DV Dongle
Old 09-10-2009, 06:56 PM
Active radio programming .... RIB is the cable used to interface with actual radios for programming.
Old 09-10-2009, 10:47 PM
No. Pending commands are OSW sequences that TRUNK88 has only seen once. TRUNK88 will not act on most events unless they are seen at least twice on the control channel. This is done to weed out the occasional bad decodes that are, unfortunately, unavoidable. Any event (that isn't based on a bad decode) that is "pending" in TRUNK88 has already taken place in the real world.
And again, no. The RIBs that relate to system channels are called Receiver Interface Boards. They have nothing to do with a radio programming level converter.
The messages in question are generated when the system detects interference (RF carrier when there should be none) on repeater input frequencies.
Similar Threads
DPS questions for your serious DPSers... texasemt13 Texas Radio Discussion Forum 11 10-30-2008 12:52 PM
bc246t vs 396 questions cchambers Uniden Scanners 10 01-16-2007 07:38 PM
First time scanner user - WORTHY QUESTIONS Jon_in_Metairie General Scanning Forum 25 05-24-2006 08:21 PM
Resources and Specific Questions doublehelix General Scanning Forum 12 05-20-2006 01:39 PM
Questions and Answers about wireless phones Radiorick Tavern Archives 10 12-23-2004 06:11 PM
