Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 09-13-2009, 08:47 PM
slypx's Avatar
Quebec DB Adm
Default BCD396XT with Pro96Com
I've been using Pro96Com with GRE's PSR600 for over a year and just received a BCD396XT three weeks ago and started using Pro96Com with it.
What I find ackward is that I have to lower the port setting to 9600 bps on the PC, on the BCD396XT and on the software underwise I loose connection within 5 minutes after started to decode ...
I've never changed anything on the PSR600, it's always at 115000 bps...
Any thoughts on that anyone ?
Slypx
Quebec DB Admin
BCD996T (2) | BCD396T | RH96 | BC780XLT | BC895XLT | PRO60 | PRO2006 | Winradio W1500E | Icom R2500 | PSR600 | BCD396XT finally home ...
Old 09-14-2009, 07:22 AM
ac7xc's Avatar
Send a message via AIM to ac7xc Send a message via Yahoo to ac7xc
Are you use a USB device? I am running a BCT15X @ 115k, but I use a USB serial port adaptor made by FTDI. The FTDI chip is the same one used in the Radio Shack 20-047 cable. Some USB devices are not very good with intensive use that is used with digital transmission and decoding. I use a
US232R-100 cable and works flawlessly with Windows XP through Win7 32/64 bit, MAC OS X and Linux.
It really is a great product and it has removed all my Serial to USB problems with all my radios and modems.
____________________
Best Regards, Keith http://home.comcast.net/~kilowattradio/
BCT15X PRO-106 PRO-92 PRO-83 TH-F6A FT897D BC346XT BC245XLT
Mac OS X, WIn7 & Linux
Old 09-14-2009, 10:16 PM
slypx's Avatar
Quebec DB Adm
I use the Uniden USB cable who works fine in uploading or downloading at 115000 ...
Slypx
Quebec DB Admin
Old 10-05-2009, 07:08 PM
slypx's Avatar
Quebec DB Adm
More Info ...
On the scanner, I have a full 5 bar signal and the tower is less than 5 miles from my listening post, signal is not a issue here.
I've used 2 different Uniden USB-1 cable on 2 different PC on different comport on each and even tried the serial cable without more success ...
So I'm left with a problem that could be in the configuration of the software, configuration of the scanner or something's wrong with the scanner itself ?
Uploading programming to the scanner seems fine.
Anyone have a better config or success than that ?
Any idea anyone ?
Slypx
Quebec DB Admin
Old 10-06-2009, 07:59 AM
mrscanner2008's Avatar
Hi
I have the same problems with my 396XT and Pro96com. I tried all bauds settings down to 38400 to make it works. So far 38400 works fine for me but nothing higher.
But with freescan, proscan, etc I set the bauds rate to 115200 and all works fine.
I didn`t try my 996xt yet.
Mrscanner2008
Icom-IC-R10, BC246T,(2) BCD996T, Icom IC-R20. Grundig FR-200 (radio SW), Pro-2067(discriminator)
Icom IC-R75
(2)BCD396XT and the new BCD996XT
my shack
Old 10-06-2009, 08:42 AM
mikey60's Avatar
Originally Posted by mrscanner2008 View Post
Hi
Mrscanner2008
I have no idea why this would be the case, as it works fine for hours on end with the PSR-500/600 at 115200. I don't know if the data coming out of the radio is still clean or has somehow changed. What does the raw dump screen look like when it stops?
http://www.psredit.com
Old 10-06-2009, 09:56 AM
slypx's Avatar
Quebec DB Adm
Hi MIke,
You're right, I can leave my PSR600 running for hours or days without a glitch, but with the 396XT ... it's painful just to keep it running for 20 minutes ...
Thanks for looking into it and keeping us up to date on your findings.
Slypx
Quebec DB Admin
Old 10-06-2009, 03:30 PM
slypx's Avatar
Quebec DB Adm
Just happened
Started decoding 2:58 pm, stopped 3:19 and raw dump screen went blank at that moment.
At 3:32 it started again to decode by itself but NO RAW DUMP activities ...???
Prior to going empty at 3:19, it started to show odd things and longer strings of code than normal and among these it showed the following ones :
5,3,000B4A60006C000EEAD9CDFE25,5,300B130000016BE97 CEA44FP2525090000000E000009F0B2264
P2P28090006BE0FFEA6FFA6BFF66
P2340A0082D1280101797970C0
P,3B09032C8032000010A007948025,5,00030000FF00FFF00 052E5F725,5,8000004F00010964E0D934AP2525990903000D 02000DD00D04A
P2009B0064EEE0ED6F05047049
P,853D00002200020A0000FFF7
P,851600001A6C020EEA797B576825,5,B0130010320209790 044FDFP2525,0000EAE00A6F096B004435FP25254002082D00 001F000FF5035
P2P2BA0090114BE2010A69706268
P,BABB0011BEE0004F000970F3
5,0,BBEA60BA6B2800000A05F7C7
5,8,100000000FFF000F7935A26P2525,90E000ED6F02DD891 8E062
P2P25B00900EE0004F0064704434
P2P25,000022D1090A2409A2640E
P2P216090040F10F010009700068
P,BA0090116BE201EA79761DFE46
5,09940B40826DE801EA6618D7
5,8,300000B0000140001035F3A025,5,90EA004A6EFA6DEFF BC6B6DP2525,001002D04F0F0909704486
P2P2BB0990BEE0004F0A6C006E66B4
P25,8090E2D0EAFFFA6FFF6ED5
P2BA059011400201EA797D6468
P,BABD0B4322000209000562FE
A25,0,B0EA13B9C901498D790E90C025,5,30022589C92409F FF0D1B6DP2525,900000EAFFFA6EFFFDBB86
P252B40A0082D14F01D000180036
Slypx
Quebec DB Admin
Old 10-06-2009, 07:52 PM
mikey60's Avatar
Originally Posted by slypx View Post
Just happened
The question is then, is that what the scanner is putting out, or is there something else going on. I'm not sure how to figure that out at this point.
