Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 09-21-2009, 01:59 PM
dmi's Avatar
dmi dmi is offline
Default (PRO96COM w/ PRO-106) Does not rx any data from PC/IF
I'm using a PRO-106 with all appropriate cables/drivers installed (works with WIN500 fine) but when I run PRO96COM and try to Read data from radio it doesn't do anything. I looked through the PDF manual and all looked good. I have what I believe are all the correct settings (set to GRE...PRO-106) and the correct COM Port, have the radio set to CCDUMP: ON hooked to the PC/IF. Have tried reading data from radio in scan mode, and having it parked on the control channel but shows no data.
I did see on occasion it said:
Decode Information
Receive Rate (%):
0% (0 out of 40)
The rest of the time it was just 0% (0 out of 0)
I can't seem to figure it out.
Please help..!
Thanks,
jay
Old 09-21-2009, 07:11 PM
mikey60's Avatar
Decode Information
Receive Rate (%):
0% (0 out of 40)
Please help..!
Thanks,
jay
What system are you trying to monitor? Pro96Com will only decode 9600 bps P25 control channels. It will not decode Motorola or EDACS systems.
http://www.psredit.com
Old 09-21-2009, 10:57 PM
Seņor Member
I'm guessing it's this system - but that's just a guess.
Montgomery County Trunking System, Montgomery County, Maryland - Scanner Frequencies
