Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 09-24-2009, 12:14 AM
Careful, I CAN hear you!
Send a message via MSN to milf Send a message via Yahoo to milf
Default PSR question T88 and UT
What are the proper settings for using the PSR's as data feeds for these two software packages?? I have a friend trying to set them up to gather some data. He got Pro96Com running lol, but for the 3600 stuff he is having issues.
Admin for AR, LA, MS, and TN
*RS PRO-96, RS PRO-92B, BC855XLT*
"Did I say something funny meow?"
"If a tree falls, do the squirrels get FEMA trailers?"
Old 09-24-2009, 12:24 AM
Highpockets's Avatar
Look at this guide, the frequencies may be different, but, it sould give you enough info to get started. The download system function will not work until the new version comes out because of the changes with the RR database.
UniTrunker Guide - UtahRadio
Steve
BC780xlt ~ BC785D ~ BCD996XT ~ PSR600
Old 09-24-2009, 12:48 AM
TY, now if anyone has a set up list for T88??
Old 09-25-2009, 12:05 AM
You're looking for a how-to on getting started with TRUNK88 and a GRE PSR scanner?
- download the Win32 TRUNK88 zipfile
- extract the files to a folder (like C:\TRUNK88)
- make a note to read the ReadMe file at some later point
- run TRUNK88; press Esc to get to the Command prompt
- tell TRUNK88 about your scanner:
- Edit Defaults / Input (control channel) parameters / CC Data Serial Port
(you press 'D', 'I', then scroll down a few times, enter the comm port number that the scanner is connected to and press Enter)
- Esc back to the main Command prompt and 'Q'uit the program (by pressing 'Q' - don't click on the big X in the upper right - ever!); this will save the CC Data port info
- rerun TRUNK88; if the scanner is properly connected and sending OSW data to the serial port, TRUNK88 will start monitoring the system and you'll see lots of stuff happening. At the top left corner of the screen, you should see the system's four digit SysID and on the right side, you'll see the OSW datastream going by
- now would be a good time to set a few system parameters; navigate to System Menu / Edit Settings / Tables, then:
- Name of System; you should enter something meaningful, like "Mayberry PS"
- System Type; the choices are: 1: Type I 800 MHz system; 2: Type II 800 MHz system; 4: Hybrid/IIi 800 MHz system; 8: 900 MHz system; 16: VHF or UHF system
- Fleetmap; unless it's an old Type I or Hybrid/IIi system, leave it blank; if it is, press Ctrl-H and have fun...
- Base Frequency; Ctrl-H will list the choices (e.g. if the system uses the standard 800 MHz bandplan, just enter "800.", for splinter, "801.", etc.). If it's a VHF or UHF system, enter the bandplan components (base frequencies, step sizes and offsets)
- after setting up the correct bandplan values, use the System Menu's Apply Current 'B'andplan dialog to correct any system frequencies that were logged before you set up the bandplan
- since most scannerheads like to see those big "TrunkTracker" talkgroup IDs on all of their systems, you'll be going back to the main Command prompt (just press Esc until you get there), then navigating to Edit Defaults / File and display formats / Talkgroup Display Format. Change it to 4 (TrunkTracker)
- whenever you Quit the program, TRUNK88 will save your trunking system data to a file; use Windows Explorer and navigate to the folder that you installed TRUNK88 in - you should see an xxxx.CTL file, where xxxx is the monitored system's ID. Right click on the file and open it in Notepad; this will give you an overview of what information TRUNK88 records
- no doubt, you'll want to populate your system .CTL file with talkgroup names; it's all covered in the RR2T88 ReadMe file. You'll find RR2T88 where you found TRUNK88: Index of /~phoenix/wap/TRUNK88
Still having problems? Head over to the TRUNK88 discussion forum and say hi: TRUNK88 : TRUNK88 forum
Old 09-25-2009, 12:24 AM
TY! Info pm'd to the person that needs it..
Old 09-25-2009, 08:47 AM
DaveNF2G's Avatar
I appreciate the tutorial as well. I haven't tried T88 with my GRE scanners yet, but now I might.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 09-29-2009, 05:53 PM
Send a message via AIM to campd715
Question
Just curious. Have you had the opportunity to try T88 with your GRE scanner? If so, how did it work out?
Thanks,
Dennis
