Originally Posted by AlabamaRS
I have had my pro 197 for about 2 months now & would like to learn more with unitrunker. I have dl'ed & install te program sevral times & and after a few moments its shuts itself down?? what am not doing correct I have the cable( 200-47 RS cable) running from the scanner to the PC is all do I need a separate audio patch cable or what?
Paul
If your using v1005 this will give you and idea on how to get started, the freq's you'll be uisng may be a different band and rebanding may not be involved, but, the setting should get you started.
If your using the new version, it still may help to get you started, some of the symbols have changed in the menu structure, and it's split screen.
Instead of reading the manual
read the guide.
In v1005 the download system function will not work, because of RR datebase changes.
UniTrunker Guide - UtahRadio
