Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Closed Thread
Old 10-05-2009, 01:10 PM
Seņor Member
Default Unitrunker 1.0.0.8
This release contains two small fixes for downloading from the RR DB SOAP interface.
1. LTR talkgroups were mangled.
2. P25 site numbers were also mangled.
More to come later.
Old 10-05-2009, 05:25 PM
bcradio's Avatar
Thanks for your hard work on this!
More to come later.
Old 10-05-2009, 08:11 PM
Seņor Member
Gah. Forgot the link.
Unitrunker
Old 10-06-2009, 09:00 PM
wvscanner's Avatar
Not that I really need it but the band plan on my apco 25 system is not displaying. I think when I was on 1.0.0.7 it did on the first tower then quit. On 8 I can not get it to display anything.
Scanning Beckley, WV
http://pages.suddenlink.net/wvsmith/
WV Scan Group
http://www.radioreference.com/forums...r-s-group.html
BC396T | PRO-2053 (tap) | BC245 | AOR8200 (tap)
Old 10-06-2009, 09:36 PM
Yep confirmed here as well. It is being decoded and stored in the XML but not being displayed on the band plan tab.
Also.....The download of of a P25 system adds/duplicates previously decoded channels with meaningless LCN's that are sequentially numbered 00-0001, 00-0002, etc. to the list of already decoded channels.
Good job on the site dowloads though, seems that is all good now.
Old 10-06-2009, 09:58 PM
Forts's Avatar
Send a message via ICQ to Forts
Anyone else having trouble with drop down boxes in menus? I just grabbed 1.0.0.8 and fired it up. First thing I tried to do is add a receiver but I can't get the drop down box to open so I can select Signal or Voice. Double clicking/clicking the down arrow on the right of the box has no effect. The machine I'm using is currently running Win2k.
Edit: Disregard... Got it to work. I wasn't clicking on the very first drop down box first... I was skipping ahead to the Signal/Voice option.
Edit #2 - How do I import all my data from UT Retro? Or can I? I've been monitoring a local system for quite some time and *really* don't want to have to re-enter all the user data manually.
Thanks!!!
Pro-106 - Pro-96 - BCT15 - BC780XLT - Pro-433 - Pro-2045 - BC-350 - Pro-43
Old 10-06-2009, 11:49 PM
Forts's Avatar
I also seem to be seeing some weird things with EDACS patches. With the Retro/DOS versions my patches would always be up in the 1600/1700/1800 ranges, but 1.0.0.8 is showing them in the 600's and 700's. Anyone else notice any EDACS patch discrepancies?
Old 10-07-2009, 12:32 AM
txzeke's Avatar
Send a message via Yahoo to txzeke
I downloaded 1.0.0.8......checked the version after download. It says it's still 1.0.0.7
PSR-500 / PSREdit500 / Pro96Com / Unitrunker
Old 10-07-2009, 12:48 AM
Muxlow's Avatar
Send a message via ICQ to Muxlow Send a message via AIM to Muxlow Send a message via MSN to Muxlow Send a message via Yahoo to Muxlow
Now that you say that, was something i was going to say too.. I noticed the same thing just forgot to post about it
Capt.Muxlow
RS 2051 2036 2040
Uniden 396T, 296D
M\A Com & Motorola's
Old 10-07-2009, 07:35 AM
wvscanner's Avatar
Thanks!!!
The way I did it was copy all the files over from retro to the gui folder. I used 1.0.0.5 to import the files to the system. Then exit and started 1.0.0.8 and they were in the list.
WV Scan Group
Old 10-07-2009, 12:25 PM
Forts's Avatar
Good to know! I will give that a try. Thanks!!
Old 10-08-2009, 10:51 AM
Default Priority?
Is there a particular reason why Priority (min of TG pri and Rad pri) isn't an available column for display? When I'm adjusting priorities, it's nice to see what the other active conversations are at.
Flash
Old 10-08-2009, 11:21 AM
davidbond21's Avatar
Send a message via ICQ to davidbond21
Actually now that y'all are saying you're seeing this, I feel less crazy. In my area, there is a patch from the local Sheriff's Office VHF system to a wide area 900 MHz EDACS. The talkgroup assigned to this patch is 1369, but on Unitrunker it keeps coming up as talkgroup 345(which has already been assigned on this system to something else). The previous version I was using(1.0.0.5) displayed this correctly I know.
(+)-3-methoxy-17-methyl-(9α,13α,14α)-morphinan
BC350C, IC-R7000, PRO-95, PRO-96, PRO-197, PSR-500
FT-7800R, Racal 25's, LPE-200's, Jaguar 725M
Old 10-08-2009, 11:33 PM
Unhappy
still not getting the band plan to work Rick
Monty N Haynes
Old 10-11-2009, 11:14 AM
mobile1's Avatar
Thumbs up
I downloaded 1.8 , opened it with 7zip , added a descriminator tap to my BC250 and tuned it to 860.0625 MHz .The local EDACS control channel. I love the new Unitrunker, it works great. Thank you !
Trunk tracking Sask.Public Safety P25 system with Win500/PSR600C and Pro96com/PSR500C and trunk tracking FleetNet 800 EDAC system with BC250/BC780XLT. Scanning everything else with an Icom R10.
Old 10-11-2009, 04:02 PM
Working well with the downloads from RR. However, its not showing TGIDs that are not on the RR database though, but the older version shows these TGIDs that are apparently only for today's edacs system testing on the Hillsborough County (Florida) east site. Is there a box to check/uncheck for this functionality?
Old 10-18-2009, 05:37 PM
blueonesparky's Avatar
I too have noticed some strange talkgroups and odd handling of higher fleet number talkgroups. Talkgroups in the 12 and 15 range (Beach Patrol and Patches/Mutual Aid for Volusia County) show up as lower fleet numbers. I've also found fleet number 08 showing as 0 when in fleet viewing mode. I'm guessing this is a bug in taking the hex data and parsing it to fleet notation? Also decimal notation was not matching with previous data... I know Volusia County didn't rework their entire system.
-Mike
Old 10-19-2009, 05:37 AM
EricR's Avatar
Same here
15-xxx is showing as 7-xxx
Old 10-20-2009, 10:20 PM
Seņor Member
Scratching my head. I don't remember changing anything in this area of the program. I'll check this out.
Old 10-20-2009, 11:22 PM
I've got two different EDACS systems with the same problem happening(both are patches to a conventional system):
Talkgroup 1369 is showing up as 345 on one system, and talkgroup 1561 is showing up as 537 on the other. The difference between both of these talkgroup variations is a value of "1024." Just some examples to help you determine what the cause is.
Closed Thread
