Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Closed Thread
Old 10-23-2009, 12:06 AM
Seņor Member
Default Unitrunker 1.0.0.9
This is a mini-release to fix the EDACS group ID problem reported in versions 1.0.0.6 through 1.0.0.8. There are no other changes, fixes or improvements at this time.
Downloads
Old 10-23-2009, 07:26 AM
DiGiTaLD's Avatar
Tried to extract it. The extraction process claims that Uniform is a password protected file. O noes!
EDIT: Disregard. Not sure what caused that, but I just got it to extract successfully.
"...interoperability will always be a pain because the people who are supposed to be working together want nothing to do with each other until something really bad happens." -shell6
Old 10-23-2009, 01:36 PM
Muxlow's Avatar
Send a message via ICQ to Muxlow Send a message via AIM to Muxlow Send a message via MSN to Muxlow Send a message via Yahoo to Muxlow
Seems to of been fixed on my end
This was for the TG's showing up wrong and patches? Like Patch TG 702 should be 1972 or something like that?
Capt.Muxlow
RS 2051 2036 2040
Uniden 396T, 296D
M\A Com & Motorola's
Old 10-23-2009, 07:18 PM
sammycookie's Avatar
Thank You Rick its works fine for me.
Pierre 73
Old 10-23-2009, 09:10 PM
Forts's Avatar
Send a message via ICQ to Forts
Yes, I believe so.
Pro-106 - Pro-96 - BCT15 - BC780XLT - Pro-433 - Pro-2045 - BC-350 - Pro-43
Old 10-24-2009, 08:49 AM
mobile1's Avatar
Thumbs up
1.0.0.9 is working great here on the local FleetNet800 EDACS site control channel. Thank you Rick.
Trunk tracking Sask.Public Safety P25 system with Win500/PSR600C and Pro96com/PSR500C and trunk tracking FleetNet 800 EDAC system with BC250/BC780XLT. Scanning everything else with an Icom R10.
Old 10-28-2009, 04:40 PM
when i try to import from the Retro version it crashes every time. Any ideas?
Old 10-28-2009, 06:25 PM
Jay911's Avatar
Send a message via ICQ to Jay911 Send a message via AIM to Jay911 Send a message via MSN to Jay911 Send a message via Yahoo to Jay911
Corruption in a data file? Does unitrunker.xml get written? If so, if you examine it, you might be able to figure out the "last" system that was imported and/or which one is crashing it.
--j.
VE6SRT
Old 10-31-2009, 06:35 PM
Seņor Member
I think I have a fix for this. I found a problem while importing some old data from 2004-2005. I'll let everyone know.
Old 11-01-2009, 12:09 AM
FlashSWT's Avatar
I just noticed that in 1.0.0.9 talkgroups I have set to "Blink" are no longer doing so. They worked fine in whatever the last version was (1.0.0.5?) that I was using for a long time before all the recent updates.
"Well, it's an emergency band scanner, it picks up everything: Fires, harbor patrol, even the police. I'm watching the watchers, Jerry." -- Kramer (Seinfeld ep.117)
Old 11-03-2009, 07:48 AM
mws72's Avatar
Wirelessly posted (BlackBerry7250/4.1.0 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
After running 1.0.0.9 for a couple of days. First keep up the great work.
My comments are: EDACS TG numbering back to normal. However now the signal is very low showing only two red bars and seeing missed or mis-decoded RIDs.
I went back and ran 1.0.0.6 and it showed full strenght.
For moto type IIi. Other than not showing type I TGs (all show as type II) it is now showing type II radios RID as the what the TG id is. When I run UT-retro and Trunk88 along side 1.0.0.9. I will see a type II change to the TG id fast (if you blink you could miss it) example a Type 1 id is 113-1. A type 2 radio id for that TG is 58881 this is instead showing as 14912 same as the what the program shows for the talkgroup.
Michael W. Scheel N0NGL // ARRL // DARC // MBRS // MVPA
Davenport IOWA // RCMA IA-011
Quad-Cities (IA-IL) Scanning www.qcscan.com
Old 11-05-2009, 11:06 AM
Unhappy
Hey Rick still unable to get the band plan in here is a pic of what the channels(after RR download) look like without the band plan in there.Is there a reason why the Band plan dont download from RR with all the other data?
Monty N Haynes
Old 11-09-2009, 12:19 AM
Maybe im just dumb but i for the life of me cannot get my 396xt to connect with Unitrunker.
settings are:
Inline,BC396xt,Signal,Running,Com4,115200,8,1,None
Scanner is set to extended output for control channel, am I doing something wrong here?
Old 11-09-2009, 08:49 PM
Seņor Member
No. Decoding from the "XT" Uniden models is broken. No ETA at the moment as to when this will be fixed.
Old 11-10-2009, 09:26 AM
DaveNF2G's Avatar
You might already know this, but UPMan's twiki page at Uniden has a revised XT protocol document linked at the bottom of the firmware updates page.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 11-12-2009, 01:25 PM
DiGiTaLD's Avatar
Just an update from here after using the latest version of UT since it's release almost non-stop except for routine automatic system updates: much more stable and reliable - I don't think its crashed even once. Whatever problems there were with stability in 1.0.0.6 and earlier seem to have been resolved. Thanks again for the great work on this software Rick.
Old 11-13-2009, 12:11 AM
Seņor Member
There's an awful volume control bug with the newer Uniden models. The program sends the radio to max volume at start up. Ouch. Anyone else noticed this?
Old 11-13-2009, 12:13 AM
Jay911's Avatar
On the contrary, I have noticed that the program mutes (or at least sets to zero) the volume on my 396XT. Haven't tried it for a while.
--j.
VE6SRT
Old 11-14-2009, 04:20 PM
Send a message via AIM to Zack08
I upgraded to this version after using the old text-only unitrunker for a couple years, and its leaps and bounds better, but I cant find a way to use a dataslicer with it. Has that feature been dropped in the new programs, or am I just missing it?
I used to like using a slicer because it would allow me to run other software on the soundcard at the same time....
Old 11-14-2009, 08:25 PM
Seņor Member
Slicers are a pain in Windows. The slicer option in Unitrunker Retro was Windows 2K/XP only. As a cheap fix, you could buy a USB sound adapter.
Closed Thread
