Unitrunker 1.0.0.9 and Windows 7
I'm having some difficulty getting Unitrunker to play nice under Windows 7 and I'm not sure what is holding me up. I had this exact same setup working under Vista and again under XP on the same machine, so I'm a bit baffled.
I have a discriminator tap in my Pro-97, connected to the right channel of my integrated SB Live Line-In (SB Live! 24-bit). Receiver is set to type Signal, with the audio port selected as 'SB Live! 24-bit', sample rate 44100, sample size 16, channel right. When I set run to 'Running' I see nothing on the scope, yet when I use another application like Audacity to monitor the Line-In I get the sounds of the control channel I'm trying to monitor on the right channel just like I expected.
I even tried Unitrunker 1.0.0.8, which is the version I had running under Vista and XP, to no avail.
Line-In is set as the default recording device, and I have adjusted the level on the Levels tab for the Line-In Properties.
Has anybody had any luck getting this working with 7 yet?
Ryan (KD0ARB)
