Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 07-16-2011, 4:45 PM
Homeboys-Scanna's Avatar
Default Are These 4-Level Data Slicers Any Good?
Order Information
Finally found a seller that has pre-built 4-level data slicers for sale. Has anyone used these and are they any good? How do I tell what kind of DC plug I need to power it with?
How To Take Better Pictures Of Your Setup: Photography 1101
"Copy, 132 and Bush, cover's code 3."
Old 07-16-2011, 4:59 PM
bryan_herbert's Avatar
They look solid but $84 is a lot to pay for a slicer.
Bryan Herbert - KE6ZGP | WQKW261
http://twitter.com/ke6zgp
http://bryanherbert.com
Old 07-16-2011, 5:08 PM
Wiki Admin Emeritus
With what application are you going to use it? There are many soundcard-based apps for trunking nowadays that a data slicer is almost nostalgic....best regards..Mike
Old 07-16-2011, 6:56 PM
Forums Moderator
Originally Posted by Homeboys-Scanna View Post
Order Information
Good quality and Rene provides good service/support. Connector is a standard 12V co-axial type as used by a lot of desktop/mobile radios (IIRC it's the same size as the Unidens).
Can't comment on the price except to say that the price is good for Europe and I've bought several because the cost seemed reasonable for the quality given the cost of the parts and my own time when building circuits.
Old 07-20-2011, 8:31 AM
Discriminator's Avatar
Unfortunately, the conversion rate from Euro to USD is quite unfavorable. However, you can find all information (schematics, PCB design) for DIY here.
Regards,
Rene (webmaster discriminator.nl)
Old 07-21-2011, 7:19 PM
Wow. Those components are so small and close together. How do people solder stuff like that? I can barely solder 2 wires together without the solder running off and drying up into a bead that falls to the counter and I'm still left with 2 bare wires. LOL.
Old 07-21-2011, 8:13 PM
n5ims's Avatar
Use a good temperature controlled soldering iron (often called a soldering station) at the minimal heat level to do the job. Using too much heat often just melts the solder and causes it to run while using the correct amount of heat melts the solder onto what you're soldering it to and give you a good joint.
Old 07-21-2011, 10:16 PM
Wiki Admin Emeritus
<bump> this question was never answered. For what kind of app would you need a 4 level slicer? best regards..Mike
Old 07-21-2011, 10:38 PM
Seņor Member
The FLEX 3200 bps paging protocol is decoded by WinFlex, POCflex, and PDW.
Old 07-22-2011, 12:50 AM
K8TEK's Avatar
Sounds to me like your tip is ruined. The tip is supposed to be shiny and hold solder on it.
Old 07-30-2011, 5:45 PM
Went ahead and ordered it and it's working just fine on the intended software program.
Old 07-31-2011, 2:46 AM
Seņor Member
I should point out that 4LFSK decoders will also handle 2 level signals. Unfortunately, the one HB just purchased does not appear to support the bit rates specific to 2 level trunking signals. They are:
3600, bps (Motorola)
4800, and 9600 bps (EDACS)
300 bps (for LTR)
As a bonus for MPT1327
7200 bps (6X over-sample) -- or --
1200 bps (native FFSK)
Old 07-31-2011, 4:05 AM
and sadly its only going to get worse if the United States loses its AAA credit rating. That $84 will quickly become $112.
Old 07-31-2011, 3:44 PM
Don't these also use a soundcard, or is a 4-level slicer still going to give better results?
Old 07-31-2011, 4:35 PM
Seņor Member
Around 1998-1999., these were slicer-only programs (except perhaps PDW which did not yet exist).
WinFLEX folded under legal pressure from Motorola.
I haven't kept up with the other pager decoders (and we're drifting off topic again).
Old 07-31-2011, 5:23 PM
Also Gnu Radio, although I think an hour or so of python hackery might be needed to interface to the soundcard (and disc. tap). Nonetheless, full source is available for it, of course. See the gr-pager subdir.
Best Regards
Max
Old 08-04-2011, 10:10 PM
I couldn't find any other sellers of 4-level data slicers though.
Old 08-04-2011, 11:13 PM
You can build an 2-level USB slicer:
Arduino bitstream-1.0 release
A 4-level enhancement for FLEX wouldn't be hard to make, especially for just one channel. A 4-level that can do P25.. that's more work.
Old 08-05-2011, 12:57 AM
Seņor Member
Texas Two Way was a former source for pre-built slicers. Most were home built. RR member Pro92b wrote an excellent analysis of the various popular slicer circuits. Apparently some were prone to oscillation. Maybe Bill can draft a new review.
Old 08-05-2011, 10:49 PM
I think I need a soldering 1101 class.
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
