Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 11-23-2011, 8:50 AM
Forts's Avatar
Mentor
Send a message via ICQ to Forts
Default Pro96COM Problems
I recently started using a new laptop and today finally got around to installing Pro96COM on it, and have run into a problem. The program will run just fine but whenever I try to acccess the Decoder Configuration menu I get an access violation stating: Access violation at address 0068A540 in module 'Pro96com.exe'. Read of address 65746169.
If I click on OK it will let me into the Decode Configuration menu however the select serial port section is greyed out as well as the Rescan button.
Any suggestions? I'm running WinXP + SP3, with .Net 3.5.
Thanks!
Old 11-23-2011, 9:31 AM
mikey60's Avatar
Are you trying to access these options while actively decoding a control channel? If so, that would explain the options that are grayed out.
I don't see that error here, so I will have a difficult time finding it. I'll see what I can do though.
http://www.psredit.com
Old 11-23-2011, 10:06 AM
Forts's Avatar
Mentor
No, I haven't been able to decode anything yet as I cannot setup the serial port in the decoder configuration. When I first launch the program I will get the access violation as soon as I attempt to go to Edit/Decode Configuration.
Old 11-23-2011, 10:11 AM
Highpockets's Avatar
Send a message via AIM to Highpockets
Can you use Wordpad or Notepad and go into your Pro96Com Config and the first line is the Com Port setting, I wonder if you do that it will solve your problem, I'm just guessing here.
Steve
BC785D ~ BCD396XT ~ BCD996XT ~ PSR600
Old 11-23-2011, 10:13 AM
Forts's Avatar
Mentor
I was wondering that myself... But I don't see a config file anywhere. Perhaps that is part of the problem right there... the program isn't able to create the config file for some reason?
Old 11-23-2011, 10:15 AM
With the new version the location changed, I'll have to look and see where mine went, don't remember off the top of my head.
Mine went to My Documents (Pro96Com) folder.
Steve
Old 11-23-2011, 10:23 AM
In the release notes it told you it changed, I believe.
Steve
Forts's Avatar
Mentor
Ok.... I have found it there as well. I will give that a try.
Actually... I've noticed that when I go into the Decode Configuration screen (after clicking OK to the Access Violation), if I click into the greyed out area where the serial port selection should be... the available ports then appear. I will grab my radio at lunch and see if things will work selecting the port this way.
Old 11-23-2011, 10:26 AM
Forts's Avatar
Mentor
Ah who reads those? And yes, it does.. I looked at the most recent entry to see what had changed but hadn't looked back over the past few to catch up on previous updates.
Old 11-23-2011, 10:27 AM
Mike may come back with an answer, mine was just a guess.
Steve
Old 11-23-2011, 10:48 AM
mikey60's Avatar
Yes, the default location for the ini file is now My Documents\Pro96Com. This was changed due to issues with User Account Control (UAC) in Windows Vista and Windows 7.
There are a couple other INI options that may help as well. It may be erroring while scanning for COM ports.
You can add these keys to the Pro96Com.ini file to change that behaviour:
[Communications]
ShowAllPorts=Yes
HighPort=255
The ShowAllPorts option disables the scan for existing ports and will show all possible COM ports, even if they don't actually exist on the computer, up to COM[HighPort]. It would be up to the user in this case to determine which COM port is actually being used. That can usually be done in the Windows Device Manager.
Old 11-23-2011, 10:51 AM
Forts's Avatar
Mentor
That did the trick! I added that to the .ini file and I no longer get the Access Violation.
Thanks so much!
Old 11-23-2011, 11:43 AM
mikey60's Avatar
Just uploaded an update that has better support for VHF systems and fixes a couple other items.
Old 11-23-2011, 12:07 PM
Thanks for the info!
Steve
Old 03-07-2012, 9:13 AM
Smile
[Communications]
ShowAllPorts=Yes
HighPort=255
Thank you so much! I was searching for a while!!
Old 10-15-2012, 4:41 PM
Default Pro96Com Access Violation when selecting decode configuration
I had this same problem in 1.10.5.187 after the number of COM ports went past the Pro96Com default configuration (was that COM5, or ??) - I had COM ports up through 13 in my Windows 7 installation. Changing the first entry in the ini file (C:\Users\UserName\Documents\Pro96Com\Pro96Com.ini ) was the workaround:
[Communications]
Port=
Latency=10
ScannerType=2
UnidenSpeed=115200
ShowAllPorts=Yes
HighPort=13
Note the the 'highport' now shown is COM16, so regardless of how you look at it this appears to be a bug.
Old 12-04-2012, 11:41 AM
After years of stress-free use, I'm suddenly also getting these violation messages. Specifically:
Access violation at address 0068CA8C in module 'Pro96Com.exe'. Read of address 65747379.
It comes up when I attempt to edit the decode configuration. Like other users, com port selections are greyed-out. When I click into the com port box, I get COM3 to appear, but; a) I can't select it, and b) my PSR500 is on COM15.
Ideas?
Old 12-04-2012, 8:04 PM
mikey60's Avatar
Are you an active decode at that point? Most of those controls are disabled when the program is actively decoding.
You could try deleting/renaming the Pro96Com.ini file and see if that helps.
Old 12-05-2012, 10:35 AM
No on the active decoding, but I was getting the message anytime I went into any of the settings menus. I re-installed the system and now anything I do in the program brings up a message saying "Error Code 3: Path not found". Another new issue since re-installation is not being able to close the program at all without killing it in Task Manager.
Old 12-05-2012, 2:14 PM
mikey60's Avatar
The error code 3 is probably an incorrect COM port. Have tried locating and deleting any Pro96Com.ini files on your system. They could be in more than one location due to the way UAC works on Windows Vista/7.
