Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 02-03-2012, 08:07 PM
Seņor Member
Default Unitrunker Release 24
Release 24 of the program is now available.
Click here to download.
Aside from bug fixes, two notable differences are support for the HP-1E as a signal receiver and the addition of start/stop buttons on the receiver toolbar.
I'll post a detailed list of fixes later. Enjoy.
Old 02-05-2012, 11:42 AM
DaveNF2G's Avatar
It seems to work well, except that I still have one pre-existing problem.
My voice follower is a BCD396T (not XT). When I set that receiver Running, the scanner goes to the Park frequency. But, when voice transmissions are actually received, the scanner does not change frequencies.
David T. Stark
Educator - Criminal Justice, Sociology
NF2G WQMY980 KYR7128
"I'm everywhere, Focker!"
Old 02-05-2012, 03:22 PM
mtindor's Avatar
OH/WV DB Admin
Send a message via MSN to mtindor
Under "Options" on the main screen, do you have "Listen" enabled?
Mike Tindor, AA8IA
Ohio/WV DB Admin
PSR500/PSR800/PRO197
www.aa8ia.org
Jefferson Co, OH Scanner Feed
Old 02-05-2012, 06:29 PM
Great release, but is there a plan to implement the Hold function for the Control Voice receiver window soon?
A "quick win" on this would be to have an Immediate Priority toggle button, that when clicked, would store the current talkgroup's Id and Priority in a placeholder variable, and then set the Priority of the talkgroup to 1.
Click the Immediate Priority toggle button again, or close the Receiver window and you set the talkgroup's Priority from the placeholder variable back to it's original Priority value from the placeholder variable.
Old 02-05-2012, 07:20 PM
Seņor Member
There is but I don't have an ETA as to just how soon. Hold will happen through the hold tool button on the voice receiver window, a hot-key, or some yet to be determined manner.
Old 02-08-2012, 11:16 AM
DaveNF2G's Avatar
I missed that setting. Problem solved. Thanks!
David T. Stark
Old 02-08-2012, 11:19 AM
DaveNF2G's Avatar
I noticed a space for Motorola fleetmap under the Info tab on a system. I entered the appropriate one in Moto format (LLLLDD), but it seems to make no difference on the Call History.
Is fleetmap still unsupported in UniTrunker?
David T. Stark
Old 02-08-2012, 04:59 PM
Seņor Member
Its still broken. You will get sizecode A for all eight banks.
Old 02-09-2012, 01:47 PM
DaveNF2G's Avatar
Hmm. This is one of the reasons I can't abandon DOS Trunker yet.
David T. Stark
Old 02-10-2012, 10:09 PM
I see there is a new "dedicated" option for receiver lock mode. What does this do?
I can't seem to find any difference between any of the three options when decoding the local EDACS system.
Old 02-10-2012, 11:54 PM
Seņor Member
I'll post a "what's new" list this weekend.
Old 02-14-2012, 12:13 PM
Default Parker County P25 Log
I thought I'd post a log of the Parker County system from v24 in case anything changed. I still can't get the VHF sites to decode.
Attachment 35916
Tom
Old 02-15-2012, 08:41 PM
frazpo's Avatar
trying to decode a P25 system. Success with a moto type 2 site but what am I missing while connecting to a P25 system? Is there a data channel I should holding to like the Moto type 2? Got to be something simple I am missing
346XT 396XT 890XLT various older models
Southwest Missouri - Joplin
http://www.mokanscanner.com
Old 02-16-2012, 08:22 AM
Texas DB Admin
Attachment 35916
I tried the other night also. I have a very strong signal from Anetta and Weatherford. I get log files filling up but the site screen never pops up and come to life like before.
I switched it over to the 700 MHz system in downtown FW and it came right up with a much worse signal.
Old 02-16-2012, 08:23 AM
Seņor Member
Thanks Tom.
Yes. The signal receiver must be tuned to the active control channel.
Old 02-18-2012, 07:17 PM
Seņor Member
Release 1.0.24.7 is out. This minor fix release addresses two issues:
a. inline decoding from a BC346XT
b. EDACS decoding from a handful of odd-ball EDACS systems.
Old 02-18-2012, 07:37 PM
Seņor Member
What's New
Inline decoding from a BC346XT fixed.
Health threshold changes.
P25 decoding accepts variable number of TSBKs per TSDU.
Clear source ID on when voice call starts on a continuation
(was displaying source ID from previous call)
Receiver window toolbar now has Start / Stop buttons.
P25 opcode 29 bug fix.
Patch logic handling fix.
Race condition fixed (ewww).
Health metrics more consistent between waveform decoding and inline decoding.
Bug fix for any toolbar button that toggles.
Better serial port buffering / timeout (customized to each radio type).
Audio decode buffers - more smaller buffers for better granularity.
P25 code base consolidation (C4FM and CQPSK were forked ages ago).
P25 now displays cross patched calls.
HP1 decode support with live oscilloscope view (sorry, no voice following).
P25 fixes - unit registration denials; group affiliation denials.
Patch related crash fixed.
Better call type display formatting (see the "SVC" column).
770 Mhz fixes for BCD396T and BCD996T voice following.
Online / offline state tracking for users that log out or leave a talkgroup.
Null pointer crash.
Uniden DMA models - capabilities mask to denote XT models.
AR3000A voice following (incomplete).
Lockmode - none, site-lock, and dedicated.
* Dedicated: ignores any data that does not match the locked site.
* You can pollute your logged data if you tune to a simular site or system with this option.
OpenSky tweak.
Remote API.
Emergency annunciation (audible alert or blinking text on an emergency call).
Archive tab now has browse button (opens Windows Explore to see your data files).
Old 02-19-2012, 12:42 PM
Originally Posted by Unitrunker View Post
What's New
OpenSky tweak.
More info on this please.
Old 02-19-2012, 01:56 PM
Default Just installed the latest release
First time Unitrunk user here.
Instructions were great, BCD996XT, everything looks like it is working except two columns dont look right
In call history and channels the freq column has all zeros...
Audience is always empty
Did I miss a switch or something ?
Scanner is holding on the control channel, C-Ch output has been set to front, the display does scroll up with talk groups that I recognize.
Old 02-19-2012, 03:03 PM
After reading more of the instructions I found out about freq needed in red...
When a new site window appears, you will see the control channel in red (color default). If the audience label displays "Frequency needed!", please type in the control channel frequency.
Regarding the JOIN
Am I correct that when the user (lE Officer, Fireman whatever) simply turns on his/her radio it will show up on UniTunker as a join because the radio must affiliate itself. Or am I out in left field
