Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 07-17-2004, 10:59 PM
Seņor Member
Default PRO-96 P25 Control Channel Display Utility - update
Overall improvements in the program and documentation!
Old 07-17-2004, 11:58 PM
ChrisP's Avatar
Rick, thanks very much for the update. Here's what it's showing me now for my federal VHF system;
-BA 00 00 17 15 01 0F 79 D5 70 F9 48 RFSS Status Broadcast Mfg 00 LRA 00 Sys 71
5 Sub 01 Site 0F channel 7-9D5(167.46250) (data,voice,registration)
-B4 00 45 05 6C 64 01 9F 0A 00 D5 FA Identifier Update 4 Base 136000000 Spacing
12500 Tx Offset 86750000
34 00 85 04 AC 64 01 9F 0A 00 3C CE Identifier Update 8 Base 136000000 Spacing
12500 Tx Offset 74750000
05 90 00 00 00 00 00 00 00 00 D1 C3 Idle
34 00 45 05 6C 64 01 9F 0A 00 31 CE Identifier Update 4 Base 136000000 Spacing
34 00 C5 1F 40 14 01 B2 15 00 FC CD Identifier Update C Base 142240000 Spacing
2500 Tx Offset 500000000
3D 00 13 25 E0 32 09 15 75 62 1B 36 Unknown op=3d Channel 1325 ID1=E032 Base=0
9157562(762006250)
-B4 00 85 04 AC 64 01 9F 0A 00 D8 FA Identifier Update 8 Base 136000000 Spacing
34 00 B5 1F 40 14 01 9F 0A 00 9B 1B Identifier Update B Base 136000000 Spacing
-BD 00 13 25 E0 32 09 15 75 62 FF 02 Unknown op=3d Channel 1325 ID1=E032 Base=0
9157562(762006250)
29 00 01 0F 2A 42 00 28 AC 04 FF D7 op=29 unknown single OSP
-BC 00 00 37 15 01 0C 49 C5 70 B9 0B Adjacent Status Broadcast Mfg 00 LRA 00 Sy
s 715 Sub 01 Site 0C channel 4-9C5(167.26250)(data,voice,registration)
9157562(762006250)
3B 00 00 BE E0 A7 15 79 D5 70 DA AA Network Status Broadcast Mfg 00 LRA 00 WAC
N BEE0A Sys 715 channel 7-9D5(167.46250)(data,voice,registration)
09 90 12 C0 00 00 00 00 00 00 F2 BA Telephone Voice Grant Update Mfg 90
34 00 65 05 08 64 01 9F 0A 00 13 1F Identifier Update 6 Base 136000000 Spacing
12500 Tx Offset 80500000
-B4 00 B5 1F 40 14 01 9F 0A 00 7F 2F Identifier Update B Base 136000000 Spacing
16 00 00 40 FF FF FF FF FF FF 52 E5 op=16 unknown single OSP
-B4 00 A5 04 7C 64 01 9F 0A 00 07 26 Identifier Update A Base 136000000 Spacing
12500 Tx Offset 71750000
34 00 25 08 3C 64 01 9F 0A 00 26 E8 Identifier Update 2 Base 136000000 Spacing
12500 Tx Offset 131750000
-B4 00 D5 1F 40 14 01 D1 55 00 EA BA Identifier Update D Base 152480000 Spacing
-B4 00 65 05 08 64 01 9F 0A 00 F7 2B Identifier Update 6 Base 136000000 Spacing
34 00 95 04 8C 64 01 9F 0A 00 34 72 Identifier Update 9 Base 136000000 Spacing
12500 Tx Offset 72750000
34 00 D5 1F 40 14 01 D1 55 00 0E 8E Identifier Update D Base 152480000 Spacing
-B4 00 55 05 30 64 01 9F 0A 00 93 39 Identifier Update 5 Base 136000000 Spacing
12500 Tx Offset 83000000
-B4 00 25 08 3C 64 01 9F 0A 00 C2 DC Identifier Update 2 Base 136000000 Spacing
Summary for site WACN BEE0A Sys 715 Sub 01 Site 0F channel 7-9D5(167.46250)
0 Base 851006250 Spacing 6250 Tx Offset 45000000
2 Base 136000000 Spacing 12500 Tx Offset 131750000
4 Base 136000000 Spacing 12500 Tx Offset 86750000
5 Base 136000000 Spacing 12500 Tx Offset 83000000
6 Base 136000000 Spacing 12500 Tx Offset 80500000
7 Base 136000000 Spacing 12500 Tx Offset 76250000
8 Base 136000000 Spacing 12500 Tx Offset 74750000
9 Base 136000000 Spacing 12500 Tx Offset 72750000
A Base 136000000 Spacing 12500 Tx Offset 71750000
B Base 136000000 Spacing 2500 Tx Offset 500000000
C Base 142240000 Spacing 2500 Tx Offset 500000000
D Base 152480000 Spacing 2500 Tx Offset 500000000
WACN BEE0A Sys 715 Sub 01 Site 0C channel 4-9C5(167.26250)
Also, just FYI, I loaded it on a second machine with Windows 2000, and it runs like a champ. No go on my Windows 98 machines, though...
- Chris
Old 07-18-2004, 03:32 PM
Default Success!
Using a XP machine at work -- now with a few questions... Are the status messages explained anywhere? I have a Astro W7 on the MPSCS system sitting next to me and when transmissions are received a unit ID pops up on the display - is that part of the hex code?
Can I assume this is part of integration into the T4 program?
- Rob
Old 07-18-2004, 04:53 PM
mikey60's Avatar
It'll be a week or so before I can try it again. Just sent my radio out for the upgrade and to have the volume control looked at since it's a little noisy, and I don't want to have the problem others are having with it.
Old 07-18-2004, 05:39 PM
Moderator
I as well cannot get it to run on a 98 machine. I did just run it on both my XP and ME machines with success.
Rick, thanks for the update. Now I just have to figure out all this info I am getting and what it all means!
Old 07-19-2004, 05:33 PM
I have it running on a W2K box. works perfectly.
Is there any provision to log what is displayed? and if so, would it be helpfull for designing a Trunker version.. Who would I forward it to?
Thanks again for all of your efforts with this project.
BTW I am monitoring the MPSCS system in the Genesee/Saginaw area. This will be a major hotbed of activity in the coming months.
PSIP
Old 07-19-2004, 09:27 PM
Put a
> output.txt
at the end of the commandline and it'll save it to a file called output.txt
- Rob
Old 07-20-2004, 12:14 AM
Seņor Member
Originally Posted by ChrisP
-BA 00 00 17 15 01 0F 79 D5 70 F9 48 RFSS Status Broadcast Mfg 00 LRA 00 Sys 715 Sub 01 Site 0F channel 7-9D5(167.46250) (data,voice,registration)
Chris;
Let me know if the frequencies are being displayed correctly. So far I have yet to see a system advertise an identifier (band plan) of zero.
-rick
Old 07-20-2004, 12:15 AM
Seņor Member
Default Re: Success!
Yes.
Correct.
-rick
Old 07-20-2004, 12:16 AM
Seņor Member
If you see anything remarkable, post the output here or send me an email.
-rick
Old 07-23-2004, 12:36 AM
wayne_h's Avatar
Forums Manager
Send a message via AIM to wayne_h
-rick
And can ya'll attach it as a text file so I don't have to hit PgDwn fifty times? Thanks! :P
-W
Old 08-05-2004, 11:31 PM
SEMTTP's Avatar
Send a message via AIM to SEMTTP Send a message via MSN to SEMTTP
Default PRO96 dump help again
pro96dmp (C) Copyright 2004 <rfmobile@swbell.net>
Version 2004.07.15
usage ...
pro96dmp port=<port-name> [ verbose=1 ] [splinter=1] [base=<freq> space=
<space> bw=<bw>]
where <port-name> is one of COM1, COM2, COM3, or COM4 (others may work)
<freq> is a base frequency in Mhz;
<space> is channel spacing in khz;
<bw> is signal bandwidth in khz.(press any key to exit)
Summary for site WACN 00000 Sys 000 Sub 00 Site 00 channel 0-000(851.00625)
... press any key to exit ...
THIS IS WHAT I GET WHEN I TRY TO RUN THE PROGRAM. SOFTWARE WAS DOWNLOADED FROM ABOVE......CABLE IS HOOKED DIRECT FROM THE COMPUTER SERIAL PORT TO THE SCANNER 1 CABLE.
ANY SUGGESTIONS??
Eric-KB8UYC
Dispatcher for FNNM(fnnm.net)
http://flickr.com/photos/erchambers
http://kb8uyc.wordpress.com
Old 08-06-2004, 12:17 AM
Are you running XP or NT?
Old 08-06-2004, 12:22 AM
SEMTTP's Avatar
Default RE:PRO96dump help again
for this computer, windows ME. So just out of curiosity I hooked the cable back up to the wifes laptop and it works just fine. I then unplugged it and plugged it back into the desktop and ran a check on com 1 and it read just fine, but it will not run the dump program....
**FYI**
I hooked my 780 up to the same com port and used butel's software and uploaded everything so the com port is working.....but not on the pro96 and the dump program!
Eric-KB8UYC
Old 08-06-2004, 09:28 AM
Windows ME is pretty close to Win98, so I imagine the same thing that is causing it not to work in Win98 is at fault here...
Old 08-06-2004, 09:56 AM
I've read through a few of the Win98/WinME problems in the other thread, and it seems that it might have something to do with the way the app uses the serial port.
Rick- If you're using the standard Windows APIs CreateFile/ReadFile/WriteFile, there are some subtle "tricks" to getting it to work across all versions of the OS. I can supply a C++ class that will do it, if you like.
-Don
