Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 12-01-2012, 5:02 AM
bravo14's Avatar
Default unitrunker laptop vs desktop
I was on my laptop for a few hours I have win7 on laptop it will run for a few mints than it quit picking up the info I have to unplug the usb and start over again than it starts quitting again. I try to use my desktop has xp on it I can't get the health mode to go from 0 to what ever it suppose to be. I followed according to this link UniTrunker | BCD996XT | BCD396XT | BC346XT | BCT15X but when I log into downlaod site goes fine but on laptop a window comes up starts searching etc... desktop doesn't show that 2nd window.
I have this set up
Type Both
Model BCD396XT
Role Signal
Run Status Run
Audio Port Soundmax digital audio
sample rate 96000
sample size 16
channel Mono
Serial Port com3
band rate 115200
data bits 8
stop bits 1
party None
logging unchecked
chase unchecked
park 855.6625
mode auto I even try FM
Health 0
lock mode none
motorola
polarity auto
Dell computers SUCK! Dude you jail you can't get a dell
Radios Alinco DJ-X10T IC-F43GT BCD396XT PSR-800
Youtube staugfl1991
Old 12-01-2012, 10:23 AM
Seņor Member
Check your task bar. The missing Window may be hidden by another window.
Old 12-01-2012, 10:27 AM
Seņor Member
Originally Posted by bravo14 View Post
I have this set up
Type Both
Model BCD396XT
Role Signal
Run Status Run
sample rate 96000
sample size 16
channel Mono
Does your '396XT have a discriminator tap? If you're trying to use the radio's CC dump feature, create the receiver as an Inline model, not a "Both" model.
Old 12-01-2012, 12:24 PM
bravo14's Avatar
I did that and it works I get 100 Health.
Youtube staugfl1991
Old 12-01-2012, 2:06 PM
bravo14's Avatar
I had another question. I don't know Action Tab mean example leaves call join. I got the svc tab stuff written down on paper.
Youtube staugfl1991
Old 12-01-2012, 3:15 PM
Seņor Member
Radios *login* to the network when first turned on and *logout* when powered off. They can *join* or *leave* a talkgroup. A dispatcher can *add* two or more talkgroups together to form a patch, and *drop* them when no longer needed. A radio can *call* a talkgroup or another radio. There are a few others.
Old 12-01-2012, 3:21 PM
bravo14's Avatar
Thanks for the info! I'll write it down.
Youtube staugfl1991
Old 12-01-2012, 4:59 PM
Seņor Member
Some light reading.
UniTrunker | Windows
Old 12-02-2012, 7:26 AM
loumaag's Avatar
Moderator
I was on my laptop for a few hours I have win7 on laptop it will run for a few mints than it quit picking up the info I have to unplug the usb and start over again than it starts quitting again. ...
This sounds like a power saving setting. (Maybe the HD is stopping.) When running on a laptop (plugged in) I have all power saving settings disabled.
