Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 12-03-2012, 9:07 AM
N8OAY's Avatar
Default Pro96Com Feature Request
Is there any possibility of getting support for Discriminator Audio input? I would like to be able to listen to the system while I am running Pro96Com. I have only one scanner that supports P25, but I have an another scanner with a Discriminator Audio Tap that will receive 700MHz frequencies that I would like to use for control channel decoding.
Thank you!
Dave
Dave Marshall N8OAY
http://www.aosc.org
PSR-500, PRO-96, BC780XLT, PRO-2067, PRO-2006/OptoScan 456, FT-90, VX7R
A former Ohio guy, now a Rookie Alabaman
Old 12-03-2012, 9:55 AM
mikey60's Avatar
Not likely. You could use Unitrunker for that though...
http://www.psredit.com
