Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 01-10-2013, 11:40 AM
bigmattyl's Avatar
Default exporting user ids in unitrunker
Hey all,
Can't quite figure out how to export user ids and labels out of unitrunker so I can import them into my HP1.
I tried the obvious of highlighting all the rows and copy/paste into excel and that didnt work
any suggestions?
Matt
Old 01-10-2013, 12:34 PM
I think you would have to export the system, which will be a .xml file, then use a text editor to remove all the other fields and xml tags.
As far as I know you can't copy/paste anything to or from Unitrunker.
Tom
Old 01-10-2013, 12:55 PM
Jay911's Avatar
Send a message via Skype™ to Jay911
Like Tom says, it's a royal pain (and no offense to Rick) but the best you can do is export to an XML file, then strip out the XML tags. If you do it right with a good search-and-replace editor (Notepad++ is my preferred one) you can replace the tags with tab characters, then copy the entire text editor buffer and paste it into Excel with relative ease. It's getting the data from the XML format into something that Excel can take that's the time-consumer/hassle.
Old 01-10-2013, 1:58 PM
bigmattyl's Avatar
Ewww... Ok thanks guys! =)
Old 01-11-2013, 1:48 AM
Seņor Member
You can strip the XML down to any format - including CSV - by using XSLT. There's an example here ...
XSLT extraction for Unitrunker
Old 01-11-2013, 3:57 AM
Jay911's Avatar
Here's one of those things that Rick keeps telling us over and over that I always forget about because I "remember" it when I'm too busy to attack it and try to use it to my advantage. And I'm sure he's sick and tired of telling us about it.
Well, I just woke up, my sleep cycle clearly still out of whack after being on night shifts the past few days, so I have a bunch of time when I won't be able to get back to sleep and I need something to do.
Old 01-11-2013, 5:11 AM
Jay911's Avatar
That's pretty slick. My apologies to you for never listening in the past.
I "massaged" groups.xsl and created a users.xsl which will do similar extraction for user entries. I also created a trio of batch files to help make running this a little easier.
Unzip xml2csv.zip into the folder where your Unitrunker.xml (or other xml files if you have done an export as per the info page Rick linked to) is located.
You can run (from a command prompt) xml2csv-grp filename (without the .xml extension) to extract group data to filename-groups.csv; xml2csv-usr filename (again, no .xml extension) to extract user data to filename-users.csv; or xml2csv filename to extract both at once to the respective filenames listed above. The XSL files I included will give slightly more descriptive column headings and wrap the alpha fields (tag, label, etc) and the color value in quotes, since Excel sometimes spazzes out on those with CSV files if they're not enquoted. Both XSL files have been tested on an exported system from my Unitrunker.xml, which contains over 200 groups and 9000+ users.
The one thing that the batch files crap out on is if your exported system name has a space in it. For example xml2csv APCO P25BEE00-123 will break with an error from the msxsl.exe program (which, btw, I didn't include in the zip, get it from the link Rick supplies on his page). The above filename is what Unitrunker will give you if you export system BEE00-123. Just rename it to something that doesn't have a space in it and you'll be fine. (I tried the usual command prompt tricks of putting the filename in quotes, but msxsl still didn't like it for some reason.)
I'd need to spend a lot more time with the tutorial to figure out how to extract, say, sites and channels/frequencies, or for example to convert flags like "logon" in the user data to human-readable values, and my brain isn't switched on enough right now to go poring through that tutorial. Hope this works well enough for you for now though.
Old 01-11-2013, 8:08 AM
I tried that a few years ago and never could get it to work. Has it been changed recently? What if you don't use MS Office or Excel?
Tom
Old 01-11-2013, 12:21 PM
Jay911's Avatar
I use OpenOffice and it loaded the CSVs from my test above just fine.
Old 01-11-2013, 6:18 PM
Seņor Member
You can wrap the path or file name in quotes. eg. "C:\Users\Bob\My Documents" instead of C:\Users\Bob\My Documents.
Old 01-11-2013, 6:48 PM
Jay911's Avatar
I tried just the file name, as in typing xml2csv "APCO P25660C5-05B" and that didn't work. Maybe I have to change the batch file and wrap the filename in quotes by default every time. (Aha, that's probably the problem - the above would be parsed as msxsl "APCO P25660C5-05b".xml groups.xsl -o "APCO P25660C5-05b"-groups.csv - I imagine having only part of the filename in quotes is making the whole thing unhappy.)
Old 01-15-2013, 2:39 PM
plaws's Avatar
Lightbulb
Has anyone written a "users.xsl" to allow extraction of User IDs? I'd like to extract those for upload by Freescan.
Peter Laws / N5UWY
I am not anti-social ... OK, a little ... but don't friend me, bro.
Old 01-16-2013, 10:44 AM
Seņor Member
Read post #7 above.
Old 01-16-2013, 10:48 AM
plaws's Avatar
Read post #7 above.
You mean actually read all the posts in a thread? Why would I do that?
Thank you.
Edited to add that I spent a little more time and had worked up the beginning of a users.xsl myself. The syntax isn't that bad once you start to play with it.
Peter Laws / N5UWY
Old 02-14-2013, 12:40 PM
I only just started using unitracker and I'm already beginning to like it.
I admire someone who uses XML instead of something more primitive. But did Rube Goldberg come up with the idea of running xml2csv from the command line?
Does anybody remember Rube Goldberg?
I'm working on converting XML files using the clip language of the text editor Notetab. That's something I might actually enjoy doing and it's something I know will work.
Old 02-14-2013, 12:51 PM
nosoup4u's Avatar
I do it in excel. I rename the unitrunker file to unitrunker.txt and load as a delimited text file using " as the delimiter. Once you do that, Column B will be the radio ID and Column D will be the tag.
John - KC2KZZ
http://www.warrenskywarn.org
PSR-800, BCD996XT (w/GPS) Home Patrol-1 & BCT15
Icom IC-80AD
