Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 01-10-2013, 9:26 PM
Saint's Avatar
Question Unitrunker (control another radio)
I have Unitrunker setup and running on my Pro-2045 (with Tap) it's decoding perfect, I have a Uniden 396t scanner with no tap, can I get Unitrunker to use the Uniden 396t scanner to listen to the voice channels, do I put in the same trunked system into my 396t how do I go about setting things up.
Any help appreciated
Steve
Uniden BC396T Scanner, ARC396TPRO Software
Old 01-11-2013, 1:44 AM
Seņor Member
Hello Saintly Steve;
Yes. There was a bug related to this specific model that was fixed a year or so ago.
The radio accepts commands to tune to a specific channel. This is independent of any programming already present in the radio.
Go to the Receivers tab. Click the "+" to create a new receiver. Set the model to BCD396T, type "Control" and an operating role of "Voice". Fill out the serial port parameters to match your radio's connection to the computer. Try 115200 bits per second with 8 data bits and no parity.
Voice following is turned off by default. To enable voice following, go the Options tab and check "Listen". You will need to set the listening threshold to be numerically equal to or greater than the listening priority of your talkgroup IDs and user IDs.
Good luck.
Old 01-11-2013, 2:09 AM
Saint's Avatar
Thumbs up voice control
Good luck.
Yep, I just did all of what you said and I will give it a try, right now there is no traffic on these systems, it's too early in the morning, no one is on yet, maybe around 7 or 8 in the morning it will get busy.
Steve
Old 01-11-2013, 2:20 AM
Seņor Member
Steve
You can set a park frequency. If the radio jumps to the park frequency when started in the receiver window, you should be good.
Old 01-11-2013, 2:38 AM
Saint's Avatar
Cool Park
The control frequency for the system is 937.0375, under control I have the CC frequency In park
And then under listen
priority=Parked
Frequency=937.0375 CC
I know this is probably wrong ????
Also do I leave my 396t scanner holding on the cc frequency 937.0375 CC
Steve
Old 01-11-2013, 8:23 AM
Chauffeur6's Avatar
DB Admin
Steve, in all honesty, there's really no reason to need to use Unitrunker to control the 396T. The system you're trying to track is a Motorola Type II with analog voice, which the 396T will track all by itself. Just program the system directly into the 396T and scan it normally.
Old 01-11-2013, 9:16 AM
Saint's Avatar
Thumbs up Second Scanner Tracking
Hi Chauffeur6, That's what I'm doing know, I was kind of bored early this morning and was trying to see how this option worked but it's easier just trunk tracking the systems with my 396t by adding the systems into the scanner in the normal way.
Steve
Old 01-11-2013, 6:30 PM
Seņor Member
Steve - the park frequency is normally a voice frequency. The signal receiver is already monitoring the control channel so placing the voice receiver on the control channel doesn't offer anything.
The one advantage of this setup over a single scanner is true a preemptive scan. The 396T - like all scanners - must leave the control channel to follow a call. If a more important call comes through, it won't know. By using a separate dedicated receiver for control channel activity, the program can preempt a low priority call with a higher one. If your ears and wallet can stand it, you can have multiple voice and signal receivers.
Of course, this isn't nearly as convenient or portable as a properly programmed handheld scanner.
Old 01-11-2013, 6:42 PM
Saint's Avatar
Default Park Frequency
Thanks Unitrunker, I'll give it a try and see how it works, nice program to figure out, very useful.
Steve
Old 01-19-2013, 6:30 PM
blueonesparky's Avatar
Send a message via AIM to blueonesparky
Might be a little off topic, but it seems closer than most I noticed in a quick thread search. Does anyone know if there is an option to place the controlled scanner back in conventional scan mode between trunked system captures for quieter systems in an area that has mixed trunked and conventional coverage?
