Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 01-16-2013, 1:27 AM
bigmattyl's Avatar
Default unitrunker and the emergency button
Hey guys,
Just wondering if I'm missing something,
I can definitely see when a user keys the radio in emergency mode, but it seems that the radios transmit some sort of signal when the button is pressed irregardless of the unit transmitting while in emergency mode.
Is it possible to see this with unitrunker also, I-calls as well
Old 01-16-2013, 1:54 AM
gewecke's Avatar
Thumbs up
Originally Posted by bigmattyl View Post
Hey guys,
Other than possibly the agency the radio is assigned to and maybe location might be transmitted, but I doubt you could see that info with a scanner.
73,
n9zas
Old 01-16-2013, 7:34 AM
Yes, Unitrunker will display emergency calls and I-calls.
UniTrunker - The RadioReference Wiki
Tom
Old 01-21-2013, 3:40 PM
bigmattyl's Avatar
what am i missing then?
cause I dont see them...
with the emergency thing, I do see when they press the talk button with emergency activitated, but i dont see when they actually hit the call button...
i-calls I dont see a thing...
something i have to turn on?
Old 01-21-2013, 6:57 PM
Seņor Member
What system are you monitoring?
Old 01-21-2013, 10:59 PM
bigmattyl's Avatar
Orange County, CA CCCS
Old 01-21-2013, 11:12 PM
Chauffeur6's Avatar
DB Admin
My tests with a P25 system show that the emergency button activation itself is either not repeated over the control channel, or Unitrunker isn't picking up on it if it is. You won't see any indication of an emergency condition until and unless the radio in emergency makes a call on the system.
Old 01-21-2013, 11:15 PM
bigmattyl's Avatar
oh really? that's interesting. I wonder how dispatch knows
Old 01-21-2013, 11:20 PM
Chauffeur6's Avatar
DB Admin
Because the button press is sent over the input frequency to the system console, which signals an emergency condition.
Old 01-21-2013, 11:21 PM
bigmattyl's Avatar
oh very cool. thanks, well that explains it
Old 01-21-2013, 11:26 PM
Markb's Avatar
Also, the CCCS does not use the iCall feature. At least I've never seen any indication of it.
Old 01-21-2013, 11:47 PM
bigmattyl's Avatar
I put the generic iCall 700000 into my scanner and get hits almost daily, the are usually encrypted though
Old 01-22-2013, 10:29 AM
Seņor Member
It may be the system sends a generic acknowledgement so the radio knows to stop sending emergency button requests - in which case I can't tell what was acknowledged. I'll look into this.
CCCS is Motorola.
Countywide Coordinated Communications System (CCCS) Trunking System, Orange County, California - Scanner Frequencies
I'll look into this as well.
Old 01-22-2013, 10:35 AM
Seņor Member
What are you using as the signal receiver? If you think the program is missing i-Calls, run the program with Decode logging turned on. After the program has captured some i-Calls, stop the receiver and send the resulting log to me (or post it here if you like). We should be able to figure out what's what.
Old 01-22-2013, 5:24 PM
bigmattyl's Avatar
I can use a descrimiator tap on an old pro 90 or I have an HP1 or a 996xt
Old 01-22-2013, 5:26 PM
bigmattyl's Avatar
as far as what makes me feel I'm missing something re: emergency activation is that out of the blue the dispatcher will say "unit with emergency activation advise control 1 on red" and unitrunker hasn't shown anything in regards to emergency traffic.
Old 01-22-2013, 5:42 PM
Seņor Member
I see the problem. The program decodes the emergency message but does nothing with it. I'll add this to my "TODO" list.
Old 01-22-2013, 8:01 PM
Chauffeur6's Avatar
DB Admin
That's great news if the emergency button depress is indeed sent back over the control channel and can be processed by Unitrunker. If you need any receiver logs from a P25 P2 system that includes an emergency button activation, let me know and I'll get it to you this week.
Old 01-23-2013, 7:08 AM
Seņor Member
Please do.
