Hello all,
Not sure if this belongs here or in the DSD forum, but I'm assuming it goes here.
I love UniTrunker. I love DSDPlus. I love my RTL sticks. But in this configuration, using the most recent public Unitrunker release, they don't love eachother.
Stick one acts as a signal. Works great on the local NJICS system, and follows great. Stick two acts as the voice, controlled by Unitrunker to follow. Audio runs from VAC line 4 into Unitrunker with no issues, but the decode rate is terrible. Actually, I can't ever make out anything, not matter how much I fiddle.
Of note, I can get "reasonable" decode rates when using SDR #, Youssef filter, WFM with about 11.5kHz bandwidth.
Obviously, I can't tinker with how the signal is treated and filtered in Unitrunker prior to it heading over to DSDPlus. I've played with VAC Line 4's audio levels to no avail. I've also recorded RAW audio from the system using the r command in DSDPlus, and running it thorough DSDTune. The results are as follows, and actually makes the attempted decode even worse:
Wed Oct 08 21:07:17 2014 : Best Decode on file test.wav was 15435 with options -dr2 -dh8 -ds50 -dd39 -dv16
Screenshot attached below. Where am I going wrong here?
As always, I appreciate any help offered from this community.
