My program seems to randomly assign LABELS to RID's therefore they are not correct. It is an existing label that is tagged to other RID's but not correct in this case. Any ideas?
There isn't enough information. Please elaborate.
When did you first notice this? What were you doing at the time the extra labels appeared? How did you assign the original label? Is it just the label or also the text color? Is this a one-time thing or on-going?
The text for your labels come from the following places:
1. RR DB download.
2. Manual edit.
3. System level template.
4. Previously saved data.
The program does not download radio IDs from the RR DB so that can be eliminated.
If you had more that one user selected while editing the label text - that would assign the same text to multiple radio IDs.
If you've edited the user template for this system, those settings are used to create new users as radio IDs are first discovered.
Hand-edits to the XML file where your radio system information is logged could potentially make a mess.
