I said it was dumb, not joking. This is really basic but I see a ton of different options.
Ok .. well presently I have a PSR500 scanner connected up to Unitrunker for Edacs control channel monitoring (800 MHz system), but the system is going away.
But .. really I need something else sometime soon. I am not going to dedicate my PSR800 to this task. That would be a bigger waste, even though I use it for recording. The upcoming Whistler 1095 will probably take that task over.
I see people using dongles .. but I know NOTHING about dongles. I am a scanner guy .. way back to the crystal age. I never has any reason to do anything else. But I do not want to dedicate a scanner for such a task.
So here are my requirements .. ability to do P25 control channel decode on 770 MHz with Unitrunker or similar. (the PSSR500 will not do the required frequencies .. so it will sit in a box to have a nice retirement when the time comes).
What are my best options ?
