I open Unitrunker, then go to the systems page, highlite/click on the system (LWIN) which I've already downloaded. At the bottom of the next page is RadioReference.com SID. The SID which is entered is 4347,that is the SID for the entire LWIN database. I want to download Slidell. When I highlite Slidell on the RR database (LWIN) page the SID# at the very top of the browser is SID 7302. When I enter 7302 I download the Wisconsin frequencies.
Any suggestions?
I know you replied again below this message and sorted out your issue, but I wanted to point out that the 7302 when you look at the Slidell site is the
Site ID, not the system ID. Note the end of the URL:
If it was the (RRDB) system ID, it would say 'sid' instead of 'siteId'.
In any case, you can't download only one site into Unitrunker. You've indicated you've already got some data in UT; just hit the download button on that entry, without changing any values, and Slidell and all the other sites will be downloaded automatically.
You
could then delete all the sites except Slidell, but Unitrunker is probably going to recreate at least one or two immediately because Slidell probably has "neighbors" (sites which the system automatically announces as being next door, so that radios know what frequencies to search when they roam).
