I am using Pro96Com & a PSR 600 scanner. I was picking up the control channel of a P25 Trunked system fine. When the system is on the primary control channel it works fine. But the system has been on a secondary control channel for a couple days now. My scanner would pick up all the info and now all it does is flash a PL instead of all the system info when tuned to the control ch. The Pro96Com doesn't do anything now. Also, my scanner was following the system fine and now it wont pick anything up but every now and then. Thanks for any help or advice you guys and gals can give me.
