Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 11-18-2006, 08:56 PM
Default A recent issue with Windows Trunker 3.8.4 a3
Recently with Eric's Windows Trunker 3.8.4 a3 decoding a Motorola Type 2 VHF system with a BC250D as the voice scanner there seems to be some problem between the software and the voice scanner properly following the correct frequency.
I've got a 100% decode rate, 270+ talkgroups and 3000+ radios and it's only been recently that I've had this problem. It's not channel specific, either...very confusing.
Has anyone else come across this problem?
Old 11-18-2006, 09:24 PM
Send a message via AIM to mikea7531
I have a problem where it doens't always want to decode the SysID and adds the input freqs as voice freqs on the screen.
-Mike
KC2SHG
Old 11-19-2006, 08:25 AM
Hmmm...haven't encountered that. For the most part everything works as expected with Windows Trunker, other than this recent issue.
Perhaps a better explanation of what's going on is when the display indicates that a talkgroup is currently using, for example, frequency 141.930 and the program is set to monitor it, the voice scanner shows a different frequency altogether.
Old 11-20-2006, 11:43 AM
Default wtrunker 3.8.4a3
Where can i get it ??
I have only a2
Thanks Forward
Ronen
http://www.ronen.org
Similar Threads
Trunker with Windows 98 matt8438 Trunking Control Channel Decoding 3 09-14-2006 01:41 PM
Microsoft releases public beta of Vista Jeffn8wb Tavern Archives 14 06-12-2006 02:39 PM
Microsoft to drop support for pre-XP Windows scannerfreak Tavern Archives 13 04-17-2006 11:20 AM
Trunker 3.8.3 in windows 2000 jets1961 Trunking Control Channel Decoding 9 02-12-2005 09:07 AM
Trunker, Windows XP, and Optocom - I'm Stumped KD4YGG Trunking Control Channel Decoding 7 08-04-2004 10:48 AM
