Go Back   The RadioReference.com Forums > Software > Trunking Control Channel Decoding
Trunking Control Channel Decoding For discussion of installation, setup, configuration, and use of the Trunker / Unitrunker digital decoding utilities (for decoding Trunking control channels)
Old 08-04-2007, 02:15 PM
Cool Unitrunker files for FL
I am looking for any Unitrunker files for areas of Florida outside of Miami-Dade & Broward Co.
I have a good Osceola Co one and everything in Miami-Dade & Broward Co.
Just switched from the old Trunker Version.
Haven't figured out if there is a way to import from the old Trunker or how to download from Radio Reference straight into Unitrunker. Thanks.
Old 08-04-2007, 06:27 PM
Seņor Member
Hi Jan;
Copy your trunker files to the Unitrunker folder. If the program sees Unitrunker data files, it will use those. If not, it will check for Trunker data files and - if found - silently import them.
Once a set of Unitrunker data files are save for a system, corresponding trunker data files are ignored.
If you're trying to import the trunker files as an afterthought you will need to delete or rename the corresponding Unitrunker files for that system and merge them by hand (eg. with notepad).
You can also download from the RR DB - which handles merging new and old data automatically. Go to [F]ind ... [S]ystem and fill out your RR DB info there.
-rick
Similar Threads
StarCom21 Programming files available N9JIG Illinois Radio Discussion Forum 0 11-24-2006 12:53 AM
Butel ARC330 and ARC396 .mem Files Not Working hotdjdave Scanner Programming Software 6 04-06-2006 09:31 PM
ARC250 and Win96 files ka3jjz Maryland Radio Discussion Forum 3 04-27-2005 11:00 PM
ARC250 and Win96 files ka3jjz Washington DC Radio Discussion Forum 0 04-26-2005 10:26 PM
BC246T UASD DEMO FILES Voyager Uniden Scanners 0 01-22-2005 04:51 PM
