Trunking ForumFor general discussion of trunked radio technologies that do not fit in to the other respective C&P forums or cross-over more than one. Please post scanner programming questions to their manufacturer's specific forum.
Not exactly. Channel spacing and frequency assignments are changing in the 800Mhz band. Parts of the 700Mhz band are also being opened for public safety commuinications on trunked systems, which will make more more spectrum space available and possibly reduce interference. But as I understand it, existing licensees will generally receive new frequencies in their current band (800Mhz) rather than being moved to a new band (700mhz or otherwise).
Rebanding only affects 800 MHz. 700 MHz is a whole different issue.
Rather than read EVERYTHING, just read the information here. www.800ta.org
Much of what is published in these forums and other unofficial places is rumor and speculation.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
